FPGA|CPLD|ASIC论坛
宋占龙
7年用户 59经验值
擅长:可编程逻辑 嵌入式技术 模拟技术 EDA/IC设计 处理器/DSP 接口/总线/驱动
FFT IP 核控制问题
`通过控制 variable streaming型FFT核进行FFT变换,首先前16周期进行1024点变换,然后跳转进行16点FFT,现在情况是,从FIFO 输出的采样数据正常输入到FFT核,控制部分sink_valid,sink_sop,sink_eop 正常输入,但就是没有输出,sink_ready,source_valid,source_imag和source_real都没有输出
已退回6积分
回帖(4)
李雷
2017-12-13 09:10:26
你的代码呢?这个可以看看生成FFT时生成的例子或者是生成的波形图。
宋占龙
2017-12-13 10:12:57
FFT控制代码
module fft_control(clk,rst,rst_fifo,w_cycle,fftpts_in,sink_eop,sink_sop,sink_valid,start_16,fft16_over,switch,re_im,out_reim,count_in,recycle,re1,re2,enable)/*synthesis noprune*/;
input clk,rst;
input start_16,fft16_over;
input re1,re2;
input [47:0] re_im;
output reg [4:0] recycle;
output [10:0] fftpts_in;
output sink_eop,sink_sop,sink_valid;
output rst_fifo;
output w_cycle,switch;
output [10:0] count_in;
output [47:0] out_reim;
output enable;
wire [47:0] out_reim;
reg enable;
reg w_cycle;
reg rst_fifo;
reg [3:0] state1;
reg [10:0] fftpts_in;
reg [10:0] count_in;
reg sink_eop,sink_sop;
reg sink_valid;
reg flag;
reg switch;
assign out_reim=flag? re_im:48'd0;
always @(posedge clk)
if(!rst) begin
        state1<=4'b0000;
        rst_fifo<=1'b1;
        w_cycle<=1'b0;
        fftpts_in<=11'd1024;
        sink_eop<=1'b0;
        sink_sop<=1'b0;
        sink_valid<=1'b0;
        count_in<=11'd0;
        flag<=1'b1;
        fftpts_in<=11'd0;
        enable<=1'b0;
end
else begin
        case(state1)
        4'b0000:        begin
                                        rst_fifo<=1'b0;
                                        flag<=1'b1;
                                        count_in<=11'd0;
                                        w_cycle<=1'b0;
                                        recycle<=5'd0;
                                        sink_eop<=1'b0;
                                        sink_sop<=1'b0;
                                        sink_valid<=1'b0;
                                        fftpts_in<=11'd1024;//一次FFT变换长度
                                        state1<=4'b0001;
                                        enable<=1'b0;
                                end
    4'b0001:begin
                                 sink_eop<=1'b0;
                              if(re1||re2) begin
                                                 sink_valid<=1'b1;                               //fifo读取使能拉高,数据开始输出,此时sink_valid拉高,数据开始输入
                                            sink_sop<=1'b1;//数据开始标志
                                            sink_eop<=1'b0;//数据结束标志
                                            state1<=4'b0011;
                                        end
                                        else begin
                                     state1<=4'b0001;
                                     end
                        end
        4'b0010:        begin
                                        sink_valid<=1'b1;
                                        sink_sop<=1'b1;
                                        sink_eop<=1'b0;
                                        state1<=4'b0011;
                                        w_cycle<=1'b0;
                                        enable<=1'b0;
                                        count_in<=count_in+11'd1;
                                end
        4'b0011: begin
                      if(count_in==11'd2045) begin
        enable<=1'b1;//周期计数使能
        sink_eop<=1'b1;
        count_in<=11'd0;
        w_cycle<=1'b1;
        state1<=4'b1001;
        end
                                        else
                                                if(count_in==11'd1022) begin
        sink_eop<=1'b1;//计满1024后拉高
        state1<=4'b0010;//开始下一个1024变换
                                                        end
                                                else begin
        sink_sop<=1'b0;
                                                  end
                                          end
        4'b1001:begin
                      //fftpts_in<=11'd0;
                      sink_valid<=1'b0;
                      sink_eop<=1'b0;
                      sink_sop<=1'b0;
                      enable<=1'b0;
                     if(enable==1'b1) begin
                        if(recycle==5'd16) begin //计满16周期后转入下一状态开始16点FFT
                           state1<=4'b0100;
                        end
                        else begin
                            enable<=1'b0;
                            recycle<=recycle+1'b1; //enable为1时拉高,计满16周期,及进行16次1024变换
                            state1<=4'b0001;
                         end
                 end
              end
        4'b0100:        begin
                        recycle=5'd0;
                        enable<=1'b0;
                                        fftpts_in<=11'd16;//
                                        sink_eop<=1'b0;
                                        w_cycle<=1'b0;
                                        count_in<=11'd0;
                                        if(start_16==1'b1) begin//16点FFT开始
                                        state1<=4'b0101;
                                end
                                else begin
                         state1<=4'b0100;
                         end
                   end
        4'b0101:        begin
                                        sink_valid<=1'b1;
                                        sink_sop<=1'b1;
                                        sink_eop<=1'b0;
                                        state1<=4'b0110;
                                end
        4'b0110:        begin
                                if(fft16_over==1'b1) begin//16点变换结束标志,开始转入1024点FFT;
                                      sink_valid<=1'b0;
                                     sink_sop<=1'b0;
                                     sink_eop<=1'b0;
                                      state1<=4'b0000;
                                      end
                                        else if(count_in==11'd14) begin
                                                sink_eop<=1'b1;
                                                count_in<=11'd0;
                                                state1<=4'b0111;
                 end
                                        else        begin
                                                        flag<=1'b1;
                                                    sink_sop<=1'b0;
                                        end
                        end
        4'b0111:        begin
                                        sink_eop<=1'b0;
                                        sink_sop<=1'b1;
                                        state1<=4'b0110;
                                        flag<=1'b1;
                                end
        default:         state1<=4'b0000;
        endcase
end
if(!rst)
        switch<=1'b1;
else
        case(fftpts_in)
                11'b10000000000:        switch<=1'b1;
                11'b00000010000:                switch<=1'b0;
        default:        switch<=switch;
        endcase
endmodule
FFT核例化
core_fft        b2v_inst5(
        .clk(clk),
        .reset_n(rst),
        .fftpts_in(fftpts_in),
        .inverse(SYNTHESIZED_WIRE_1),
        .sink_valid(sink_valid),
        .sink_sop(sink_sop),
        .sink_eop(sink_eop),
        .sink_real(SYNTHESIZED_WIRE_5),
        .sink_imag(SYNTHESIZED_WIRE_4),
        .sink_error(SYNTHESIZED_WIRE_3),
        .source_ready(SYNTHESIZED_WIRE_2),
        .source_valid(source_valid),
        .fftpts_out(),
        .source_error(),
        .sink_ready(),
        .source_sop(),
    .source_eop(),
        .source_imag(source_imag[36:0]),
        .source_real(source_real[36:0]));
宋占龙
2017-12-14 19:17:32
引用: szldsj 发表于 2017-12-13 10:12
FFT控制代码
input clk,rst;
问题解决了,是复位的问题,复位要循环,就是当一次FFT结束后要再次复位然后开始下一次变换
聆听我的声音
2018-4-4 16:39:44
您好 我是个菜鸟 能问下使用IP核时  为什么设置完 那个芯片图没有生成
