工程师小经验:快速查找原理图元器件资料资料下载
消耗积分:10 | 格式:pdf | 大小:404.42KB | 2021-04-03
20762
分享资料个
我们在设计原理图或者查看原理图时,经常需要到网站上搜索某个元器件的相关资料,看能否找到规格书来查看。每次都要打开相关网站,输入关键词去搜索,这样的重复操作效率不是很高。有没有办法在原理图上,选中某个元器件,下一步就已经在网站上搜索了这个元器件的关键词,并找出了相关网页来。答案是有的,就是编写一个脚本,选中某个元器件,运行脚本就能实现这个功能。下面介绍一下这个方法。 首先,打开原理图的脚本编辑器,编写以下代码。 参考代码: Sub Main Begin Dialog UserDialog 260,140,"Select a Web ",.CallbackFunc ' %GRID:10,7,1,1 Text 50,84,170,14,"",.Text1 OKButton 40,112,90,21,.OK CancelButton 140,112,90,21  OptionGroup .Manufacturer OptionButton 60,14,140,14,"baidu",.OptionButton1 OptionButton 60,35,90,14,"szlcsc",.OptionButton2 OptionButton 60,56,90,14,"taobao",.OptionButton3 End Dialog Dim dlg As UserDialog Dim attrs As Attributes If Dialog(dlg) = -1 Then 'OK was pressed Set objs = ActiveDocument.GetObjects(plogObjectTypeComponent, "", True) For Each part In objs Set attrs = part.Attributes compName = attrs("Value") Next part 'compName = objs.Item(1).AttrVal(part, "Description") Set ie = CreateObject("InternetExplorer.Application") 'compName = objs.Item(1).AttrVal(part, "Description") Set ie = CreateObject("InternetExplorer.Application") ie.Visible = True Select Case dlg.Manufacturer Case 0 'ie.Navigate("http://www-s.ti.com/sc/docs/psheets/pids2.htm") ie.Navigate("http://www.baidu.com/s?wd="& compName) SendKeys compName & "~" Case 1 ie.Navigate("https://so.szlcsc.com/global.html?&hot-key=CC2530F256RHAR") Case 2 ie.Navigate("https://s.taobao.com/search?keywords=" & compName) End Select End If End Sub Rem See DialogFunc help topic for more information. Private Function CallbackFunc(DlgItem$, Action%, SuppValue%) As Boolean Select Case Action% Case 1 ' Dialog box initialization Document_SelectionChange Case 2 ' Value changing or button pressed Case 3 ' TextBox or ComboBox text changed Case 4 ' Focus changed Case 5 ' Idle Rem CallbackFunc = True ' Continue getting idle actions End Select End Function Public Sub Document_SelectionChange() Set objs = ActiveDocument.GetObjects(plogObjectTypeComponent, "", True) DlgEnable "OK", False If objs.Count = 1 Then compName = objs.Item(1).Name DlgText "Text1", "Selected Part: " & compName DlgEnable "OK", True ElseIf objs.Count > 1 Then DlgText "Text1", "Multiple Selection" Else DlgText "Text1", "Select a part" End If End Sub   然后,选中需要查找的元器件,运行脚本,就会弹出一个网站的页面让我们选择,这里设置了百度,立创和淘宝。 最后,任选其中一个网站,点击确认,就会自动打开相对应的网站,搜索元器件的关键词,找到相关的内容供我们查看,非常方便快捷。
评论(0)
发评论
下载排行榜
'+ ''+ '' ); $.get('/article/vipdownload/aid/'+webid,function(data){ if(data.code ==5){ $(pop_this).attr('href',"/login/index.html"); return false } if(data.code == 2){ //跳转到VIP升级页面 window.location.href="//m.jibsdb.com/vip/index?aid=" + webid return false } //是会员 if (data.code > 0) { $('body').append(htmlSetNormalDownload); var getWidth=$("#poplayer").width(); $("#poplayer").css("margin-left","-"+getWidth/2+"px"); $('#tips').html(data.msg) $('.download_confirm').click(function(){ $('#dialog').remove(); }) } else { var down_url = $('#vipdownload').attr('data-url'); isBindAnalysisForm(pop_this, down_url, 1) } }); }); //是否开通VIP $.get('/article/vipdownload/aid/'+webid,function(data){ if(data.code == 2 || data.code ==5){ //跳转到VIP升级页面 $('#vipdownload>span').text("开通VIP 免费下载") return false }else{ // 待续费 if(data.code == 3) { vipExpiredInfo.ifVipExpired = true vipExpiredInfo.vipExpiredDate = data.data.endoftime } $('#vipdownload .icon-vip-tips').remove() $('#vipdownload>span').text("VIP免积分下载") } }); }).on("click",".download_cancel",function(){ $('#dialog').remove(); }) var setWeixinShare={};//定义默认的微信分享信息,页面如果要自定义分享,直接更改此变量即可 if(window.navigator.userAgent.toLowerCase().match(/MicroMessenger/i) == 'micromessenger'){ var d={ title:'工程师小经验:快速查找原理图元器件资料资料下载',//标题 desc:$('[name=description]').attr("content"), //描述 imgUrl:'https://'+location.host+'/static/images/ele-logo.png',// 分享图标,默认是logo link:'',//链接 type:'',// 分享类型,music、video或link,不填默认为link dataUrl:'',//如果type是music或video,则要提供数据链接,默认为空 success:'', // 用户确认分享后执行的回调函数 cancel:''// 用户取消分享后执行的回调函数 } setWeixinShare=$.extend(d,setWeixinShare); $.ajax({ url:"https://www.elecfans.com/app/wechat/index.php?s=Home/ShareConfig/index", data:"share_url="+encodeURIComponent(location.href)+"&format=jsonp&domain=m", type:'get', dataType:'jsonp', success:function(res){ if(res.status!="successed"){ return false; } $.getScript('https://res.wx.qq.com/open/js/jweixin-1.0.0.js',function(result,status){ if(status!="success"){ return false; } var getWxCfg=res.data; wx.config({ //debug: true, // 开启调试模式,调用的所有api的返回值会在客户端alert出来,若要查看传入的参数,可以在pc端打开,参数信息会通过log打出,仅在pc端时才会打印。 appId:getWxCfg.appId, // 必填,公众号的唯一标识 timestamp:getWxCfg.timestamp, // 必填,生成签名的时间戳 nonceStr:getWxCfg.nonceStr, // 必填,生成签名的随机串 signature:getWxCfg.signature,// 必填,签名,见附录1 jsApiList:['onMenuShareTimeline','onMenuShareAppMessage','onMenuShareQQ','onMenuShareWeibo','onMenuShareQZone'] // 必填,需要使用的JS接口列表,所有JS接口列表见附录2 }); wx.ready(function(){ //获取“分享到朋友圈”按钮点击状态及自定义分享内容接口 wx.onMenuShareTimeline({ title: setWeixinShare.title, // 分享标题 link: setWeixinShare.link, // 分享链接 imgUrl: setWeixinShare.imgUrl, // 分享图标 success: function () { setWeixinShare.success; // 用户确认分享后执行的回调函数 }, cancel: function () { setWeixinShare.cancel; // 用户取消分享后执行的回调函数 } }); //获取“分享给朋友”按钮点击状态及自定义分享内容接口 wx.onMenuShareAppMessage({ title: setWeixinShare.title, // 分享标题 desc: setWeixinShare.desc, // 分享描述 link: setWeixinShare.link, // 分享链接 imgUrl: setWeixinShare.imgUrl, // 分享图标 type: setWeixinShare.type, // 分享类型,music、video或link,不填默认为link dataUrl: setWeixinShare.dataUrl, // 如果type是music或video,则要提供数据链接,默认为空 success: function () { setWeixinShare.success; // 用户确认分享后执行的回调函数 }, cancel: function () { setWeixinShare.cancel; // 用户取消分享后执行的回调函数 } }); //获取“分享到QQ”按钮点击状态及自定义分享内容接口 wx.onMenuShareQQ({ title: setWeixinShare.title, // 分享标题 desc: setWeixinShare.desc, // 分享描述 link: setWeixinShare.link, // 分享链接 imgUrl: setWeixinShare.imgUrl, // 分享图标 success: function () { setWeixinShare.success; // 用户确认分享后执行的回调函数 }, cancel: function () { setWeixinShare.cancel; // 用户取消分享后执行的回调函数 } }); //获取“分享到腾讯微博”按钮点击状态及自定义分享内容接口 wx.onMenuShareWeibo({ title: setWeixinShare.title, // 分享标题 desc: setWeixinShare.desc, // 分享描述 link: setWeixinShare.link, // 分享链接 imgUrl: setWeixinShare.imgUrl, // 分享图标 success: function () { setWeixinShare.success; // 用户确认分享后执行的回调函数 }, cancel: function () { setWeixinShare.cancel; // 用户取消分享后执行的回调函数 } }); //获取“分享到QQ空间”按钮点击状态及自定义分享内容接口 wx.onMenuShareQZone({ title: setWeixinShare.title, // 分享标题 desc: setWeixinShare.desc, // 分享描述 link: setWeixinShare.link, // 分享链接 imgUrl: setWeixinShare.imgUrl, // 分享图标 success: function () { setWeixinShare.success; // 用户确认分享后执行的回调函数 }, cancel: function () { setWeixinShare.cancel; // 用户取消分享后执行的回调函数 } }); }); }); } }); } function openX_ad(posterid, htmlid, width, height) { if ($(htmlid).length > 0) { var randomnumber = Math.random(); var now_url = encodeURIComponent(window.location.href); var ga = document.createElement('iframe'); ga.src = 'https://www1.elecfans.com/www/delivery/myafr.php?target=_blank&cb=' + randomnumber + '&zoneid=' + posterid+'&prefer='+now_url; ga.width = width; ga.height = height; ga.frameBorder = 0; ga.scrolling = 'no'; var s = $(htmlid).append(ga); } } openX_ad(828, '#berry-300', 300, 250);
