C51全局初始化及精确延时程序,51单片机精确延时程序
1.4w人已加入
关键字:单片机延时程序
*                                          Initialization Program
*                                               QiZhao,2007
*                                           All Rights Reserved
* File      : initial.h
* By        : QiZhao
* Contact   :
zq1987731@163.com
* Version   : V2.1 γ
* Corrector : QiZhao
* Date      : 2008.2.1 (Last modified)
* Remarks   : Common set of macro definitions keyword, and by setting controlled
*             crystal oscillator frequency precision delay subroutine.
    #ifndef   _initial_h_
    #define   _initial_h_
*                                         Global macro definitions
    #include               // AT89S52
    #include              // Absolute address access
    #include              // Related to the string
    #include             // Related to Assembly Language
    #include               // Unicode conversion
    #include                // Mathematics functions packet
    #include               // Standard input or output
    #include              // Memory Management
    #define TRUE    1
    #define FALSE   0
    #define bool    bit             // Boolean variable
    #define uchar   unsigned char
    #define uint    unsigned int
    #define ulong   unsigned long
    #define FOSC    12000000UL      // The frequency of crystal
    #define NOP     _nop_();
*                                          Accurate delay(5us,10us)
    void delay10us (void)            // FOSC->12000000
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
    void delay5us (void)             // FOSC->12000000
        NOP
*                                          Accurate delay(1ms~255ms)
    #define WAITE_HI (FOSC / 2 / 12 / 1000 >> 8 )
    #define WAITE_LOW (FOSC / 2 / 12 / 1000 & 0xFF)
    void delayms (uchar time)
        do
            uchar j;
            #if WAITE_HI != 0
                j = 0;
                    uchar i;
                    for(i = WAITE_HI; i > 0; i--)
                        while (--j);
            #endif
            #if WAITE_LOW != 0
                j = WAITE_LOW;
                while (--j);
            #endif
        }while (--time);
*                                            Includes not repeat
    #endif
  • 相关推荐
