LCD1602的驱动程序的代码编写
控制/MCU
1924人已加入
#include
#include "./delay/delay.h"
#define LCDPORT P0
#define LCD_WRITE_DATA 1
#define LCD_WRITE_COM 0
sbit RS = P2^4;
sbit RW = P2^5;
sbit E = P2^6;
unsigned char flag = 1;
unsigned char shi = 23, fen = 59, miao = 50;
void lcd1602_write(unsigned char byte, unsigned char flag)
if(flag)
RS = 1; //选择输入的数据为数据
else
RS = 0; //选择输入的数据为命令
RW = 0; //写
E = 1; //选中lcd
LCDPORT = byte;
delay_ms(5);
E = 0; //失能LCD 高电平有效
void lcd_init()
delay_ms(15);
lcd1602_write(0x38,LCD_WRITE_COM); //设置8位数据接口,两行指令,5*8点阵字符
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
lcd1602_write(0x08,LCD_WRITE_COM); //关闭显示,关闭光标和闪烁
delay_ms(5);
lcd1602_write(0x01,LCD_WRITE_COM); //清屏
delay_ms(5);
lcd1602_write(0x06,LCD_WRITE_COM); //设置指针方式,画面不平移
delay_ms(5);
lcd1602_write(0x0c,LCD_WRITE_COM); //设置指针方式,画面不平移
delay_ms(5);
void lcd_dis_char(unsigned char x, unsigned char y, unsigned char *s)
if(0 == x)
lcd1602_write(y + 0x80,LCD_WRITE_COM);
else if(1 == x)
lcd1602_write(y + 0xc0,LCD_WRITE_COM);
while(*s)
lcd1602_write(*s, LCD_WRITE_DATA);
s++;
void time0_init()
EA = 1;
TMOD |= 0x01;
TH0 = (65536 - 20000) / 255;
TL0 = (65536 - 20000) % 255;
ET0 = 1;
TR0 = 1;
void time0_isr() interrupt 1
static unsigned char i = 0;
i++;
if(50 == i)
i = 0;
miao++;
if(60 == miao)
miao = 0;
fen++;
if(60 == fen)
fen = 0;
shi++;
if(24 == shi)
shi = 0;
void lcd_diaplay_time() //时间的显示函数
lcd1602_write(0x80 + 7, LCD_WRITE_COM);
lcd1602_write((shi / 10) + 0x30,LCD_WRITE_DATA);
lcd1602_write((shi % 10) + 0x30,LCD_WRITE_DATA);
lcd1602_write(':',LCD_WRITE_DATA);
lcd1602_write((fen / 10) + 0x30,LCD_WRITE_DATA);
lcd1602_write((fen % 10) + 0x30,LCD_WRITE_DATA);
lcd1602_write((miao / 10) + 0x30,LCD_WRITE_DATA);
lcd1602_write((miao % 10) + 0x30,LCD_WRITE_DATA);
void lcd_dis_hex() //显示字符或数字
unsigned char temp = 0x2b;
lcd1602_write(0x80,LCD_WRITE_COM);
lcd1602_write((temp / 16) + 0x30,LCD_WRITE_DATA);
lcd1602_write((temp % 16) + 0x37,LCD_WRITE_DATA);
void main()
time0_init();
lcd_init();
lcd_dis_hex();
lcd_dis_char(0,2,"time:");
while(1)
lcd_diaplay_time();
#include
#define LCDPORT P0
sbit RS = P2^4;
sbit RW = P2^5;
sbit E = P2^6;
if(flag)
else
RW = 0; //写
E = 1; //选中lcd
LCDPORT = byte;
delay_ms(5);
void lcd_init()
delay_ms(15);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
delay_ms(5);
if(0 == x)
else if(1 == x)
while(*s)
s++;
void time0_init()
EA = 1;
TMOD |= 0x01;
ET0 = 1;
TR0 = 1;
i++;
if(50 == i)
i = 0;
miao++;
if(60 == miao)
miao = 0;
fen++;
if(60 == fen)
fen = 0;
shi++;
if(24 == shi)
shi = 0;
void main()
time0_init();
lcd_init();
lcd_dis_hex();
while(1)
lcd_diaplay_time();
评论(0)
发评论
1368979359 2020-06-17
0 回复 举报
全是错误 收起回复
