乐鑫技术交流
王婷
7年用户 971经验值
win10家庭版安装idf V4.3.1后编译例程失败了,怎么解决?
    我安装了V4.3.1版本的idf后, 编译examples->get_started -> hello_world 例程失败, 编译主机为 Windows 10 64位家庭中文版 10.0.19041.1266 AMD 4800H
    根据ESP32-DevKitC V4 入门指南 , 从https://dl.espressif.com/dl/esp-idf/?idf=4.4 下载离线安装版本安装ESP-IDF 工具安装器,安装过程中显示一切正常.
    安装完毕后, power shell/cmd 显示环境变量设置成功, 然后按照入门指南进入到hello_world目录, 编译:
    idf.py set-target esp32c3
    显示如下错误:
    PS D:esp32examplesget-startedhello_world> idf.py set-target esp32c3
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Executing action: set-target
Set Target to: esp32c3, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old.
Running cmake in directory d:esp32examplesget-startedhello_worldbuild
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32c3 -DCCACHE_ENABLE=1 d:esp32examplesget-startedhello_world"...
-- Found Git: D:/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: D:/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe
-- Check for working C compiler: D:/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe
-- Check for working C compiler: D:/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe -- broken
CMake Error at D:/.espressif/tools/cmake/3.16.4/share/cmake-3.16/Modules/CMakeTestCCompiler.cmake:60 (message):
  The C compiler
    "D:/.espressif/tools/riscv32-esp-elf/esp-2021r1-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe"
  is not able to compile a simple test program.
  It fails with the following output:
    Change Dir: D:/esp32/examples/get-started/hello_world/build/CMakeFiles/CMakeTmp
    Run Build Command(s):C:/cygwin64/bin/ninja.exe cmTC_90c87 && [1/2] Building C object CMakeFiles/cmTC_90c87.dir/testCCompiler.c.obj
    FAILED: CMakeFiles/cmTC_90c87.dir/testCCompiler.c.obj
    D:.espressiftoolsriscv32-esp-elfesp-2021r1-8.4.0riscv32-esp-elfbinriscv32-esp-elf-gcc.exe   -march=rv32imc -o CMakeFiles/cmTC_90c87.dir/testCCompiler.c.obj   -c testCCompiler.c
    /bin/sh: D:.espressiftoolsriscv32-esp-elfesp-2021r1-8.4.0riscv32-esp-elfbinriscv32-esp-elf-gcc.exe: command not found
    ninja: build stopped: subcommand failed.
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
  D:/esp32/tools/cmake/project.cmake:311 (__project)
  CMakeLists.txt:6 (project)
-- Configuring incomplete, errors occurred!
See also "D:/esp32/examples/get-started/hello_world/build/CMakeFiles/CMakeOutput.log".
See also "D:/esp32/examples/get-started/hello_world/build/CMakeFiles/CMakeError.log".
cmake failed with exit code 1
        同样的步骤和同样的安装文件, 在家里的win10上安装后编译无问题, 不同之处是家里电脑为win10专业版,想问问各位是否知道怎么回事? 恳请指导一二.
        PS: 怀疑为安装问题, 卸载了重装问题依旧.
张辉
2024-6-19 16:34:54
根据您提供的信息,您在 Windows 10 家庭版上安装了 ESP-IDF V4.3.1,并尝试编译 hello_world 例程,但遇到了编译失败的问题。以下是一些建议来解决这个问题:
1. 确保安装了所有必要的依赖项:
   - 安装 Python 3.7 或更高版本(建议使用 Python 3.8)
   - 安装 Git
   - 安装 Ninja
   - 安装 CMake
   - 安装 MSYS2(包括 mingw-w64-x86_64-gcc-g++ 和 mingw-w64-x86_64-python3)
2. 确保环境变量设置正确:
   - 将 Python 添加到 PATH 环境变量
   - 将 Git 的 bin 目录添加到 PATH 环境变量
   - 将 Ninja、CMake 和 MSYS2 的 bin 目录添加到 PATH 环境变量
3. 打开命令提示符或 PowerShell,运行以下命令来检查环境变量是否设置正确:
   python --version
   git --version
   cmake --version
   ninja --version
4. 确保您已经克隆了 ESP-IDF 的示例项目:
   git clone https://github.com/espressif/esp-idf.git
5. 进入 hello_world 目录,设置目标为 esp32c3:
   cd esp-idf/examples/get-started/hello_world
6. 尝试清理并重新编译项目:
   idf.py clean
   idf.py build
7. 如果编译仍然失败,请查看编译过程中的错误信息,以便找到具体的问题所在。您可以在错误信息中搜索可能的解决方案。
8. 如果问题仍然无法解决,您可以尝试升级到 ESP-IDF 的最新版本(例如 V4.4),因为新版本可能修复了一些已知的问题。
希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多的错误信息,以便我们能够更好地帮助您。
