FPGA|CPLD|ASIC论坛
h1654156194.3292
9年用户 9经验值
[资料]
ATF1504AS,Found wrong device(s) in hardware
用atmisp通过byteblaster2向ATF1504AS编写程序,结果ATMISP报错,错误信息如下:Found wrong device(s) in hardware。在下查了查帮助文档上的内容,出现这个错误为:The devices specified in the ATMISP chain file do not match the actual devices found in the JTAG hardware chain. At the beginning of a JTAG programming process, ATMISP will read the device IDs from all of the devices in the JTAG chain and then compare them with the expected device IDs。
这个该如何去解决,有知道的大神吗,赐教一下好吗
已退回7积分
h1654155947.9102
2016-3-22 13:42:11
看不懂看不懂看不懂
