求助各位大侠下面这段程序中的void image_projec
ting ()函数该如何进行优化呢?进行线性汇编的话该如何进行代码修改呢?* FILENAME: app_process.c
* PLATFORM: VC6.0
* The c file is used to compute the projection iamge
/*--------------the head file declaration-------------------------------------*/
#include
#include
#include
#include "app_extern.h"
#include "app_main.h"
/*----------------------the function of computing the prejectiong image -----------------*
* 此函数用于计算该图像的目标放投影图 *
* 即:计算图像中每一点成为目标的概率 *
* 反投影图中越亮的点表明该点越有可能成为目标 *
* 由两部分在组成:1.计算目标的归一化直方图 *
* 2.计算各个像素点成为目标的概率 *
* 注:本文在图像上建立的坐标系如下图所示 *
* 0---------------> X(352) *
* V y (288) *
void image_projecting ()
object_modeling(Y_data);
compute_prob_project(Y_data,Y_shadow);
/*------------------the function of computing the probility of the pixel -----------------*
* 此函数用来计算图像中各像素点成为目标的概率 *
void compute_prob_project(unsigned char *p_data ,unsigned char*p_data_project)
int i ;
unsigned short *prob=Histogram_object;
unsigned char temp;
for(i=0;i
temp=*(p_data++);
*p_data_project++=(unsigned char)(*(prob+temp));
/*----------------------the function of compute the histogram ---------------------------*
* 此函数用来计算目标的归一化直方图 *
void object_modeling(unsigned char *p_data)
int i,j,t;
unsigned short x1=object_location_x1;
unsigned short x2=object_location_x2;
unsigned short y1=object_location_y1;
unsigned short y2=object_location_y2;
unsigned short scale_window;
scale_window=(x2-x1)*(y2-y1);
memset(prob,0,512);
for(j=y1;j
for(i=x1;i
*(prob+(*(p_data+j*width+i)))+=1;
for(i=0;i<256;i++)
*(prob+i)= *(prob+i)*255*3/scale_window;
printf("The object model is constructedn");
/*-------------------the function of drawing a window around the object ------------------*
* 此函数用来标注目标在图像中的位置 *
void draw_window (unsigned char *src_data )
int i ;
unsigned short window_w=x2-x1;
unsigned short window_h=y2-y1;
unsigned char *src;
src=src_data+y1*width+x1;
/****************标注平行于x轴的框子*************************************/
for(i=0;i
*(src+i)=255;
*(src+width+i)=255;
*(src+i+(window_h-1)*width)=255;
*(src+i+window_h*width)=255;
/****************标注平行于y轴的框子*************************************/
for(i=0;i
*(src+i*width)=255;
*(src+i*width+1)=255;
*(src+i*width+window_w)=255;
*(src+i*width+window_w-1)=255;
/*----------------------the function of write the output information --------------------*
* 此函数用来将所做的题目号和耗费时间加到图像数据中 *
* 注:* 请勿修改此项* *
void fun_out(unsigned char *buffer_in, float costtime)
int j ;
unsigned char num = 17;
double tt=costtime;
for (j = 0 ; j < 10; j ++)
buffer_in[j] = 0;
buffer_in[0] = num;
memcpy(&buffer_in[1],&tt,8);
/*********************************** end of the file **********************************************/
