英飞凌
刘慧
8年用户 1832经验值
ModusToolbox™ 3.2 Dashboard工程生成错误的原因?
在生成工程时,出现如下错误:
Opening project creator from C:/Users/XXX/ModusToolbox/tools_3.2/project-creator/project-creator.exe
Project Creator Status:
Project:          Hello_World_1
  Status:        failed
                [1]:        [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/device-configurator-cli/device-configurator-cli-20240626.170103.333-14676.log"
                [2]:        [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/device-configurator/device-configurator-cli.exe --build D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus --readonly"
                [3]:        [INFO] Log file= "C:/Users/XXX/AppData/Local/Temp/hardware-config-server/hardware-config-server-20240626.170104.542-5352.log"
                [4]:        [INFO] Command line= "C:/Users/XXX/ModusToolbox/tools_3.2/hardware-config-server/hardware-config-server.exe --config D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus"
                [5]:        [INFO] Library paths:  "D:/Infineon/03/mtb_shared/mtb-pdl-cat1/release-v3.10.1/props.json;C:/Users/XXX/.modustoolbox/global/device-db/release-v4.16.0/props.json"
                [6]:        Error loading file. The design file was locked by another host. The file is locked by "闂佽法鍠愰弸濠氬箯閻戣姤鏅搁柡鍌樺�栫�氳瀵� [D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus]
                [7]:        Failed to load 'D:/Infineon/03/Hello_World_1/bsps/TARGET_APP_CYW920829M2EVK-02/config/design.modus'.
                [8]:        Failed to export the "Hello_World_1" application to Eclipse IDE for ModusToolbox闁筹拷
Unable to import the project: Hello_World_1. Try "Import Existing Application" from the quick-panel. If issues persist, retry project creator.
No new/valid projects found.
张览秀
2024-7-26 16:07:42
ModusToolbox™ 3.2 Dashboard工程生成错误的原因可能有以下几点:
1. 权限问题:请确保您有足够的权限访问指定的文件夹和文件。尝试以管理员身份运行ModusToolbox™ 3.2 Dashboard。
2. 路径问题:检查项目路径(D:/Infineon/03/Hello_World_1)是否正确,以及文件夹是否存在。如果路径或文件夹不存在,请创建相应的文件夹或更改路径。
3. 项目名称问题:检查项目名称(Hello_World_1)是否符合命名规范,不包含非法字符或空格。
4. 软件安装问题:确保ModusToolbox™ 3.2已正确安装,所有依赖组件都已安装并更新到最新版本。
5. 系统兼容性问题:检查您的操作系统是否与ModusToolbox™ 3.2兼容。如果存在兼容性问题,请尝试在兼容的操作系统上运行。
6. 项目配置问题:检查项目配置文件(如Makefile、project.yml等)是否正确配置,没有错误或遗漏。
7. 其他潜在问题:如果以上方法都无法解决问题,可能存在其他未知的错误。您可以尝试查看ModusToolbox™ 3.2的日志文件,查找更详细的错误信息,或者联系技术支持寻求帮助。
请按照这些步骤逐一排查问题,找到导致工程生成错误的原因,并进行相应的解决。
