乐鑫技术交流
小麦地
11年用户 1587经验值
ESP32-S2使用IDF MASTER分支编译出现/http-parser文件夹缺失怎么解决?
git describe --tags
v4.4-dev-1594-g1d7068e4b
如下输入
idf.py  set-target esp32s2  menuconfig
Adding "set-target"'s dependency "fullclean" to list of commands with default set of options.
Executing action: fullclean
Build directory '/mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/build' is empty. Nothing to clean.
Executing action: set-target
Set Target to: esp32s2, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old.
Running cmake in directory /mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s2 -DIDF_TARGET=esp32s2 -DCCACHE_ENABLE=0 /mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2"...
-- Found Git: /usr/bin/git (found version "2.25.1")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: /home/inkfish/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc
-- Check for working C compiler: /home/inkfish/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc
-- Check for working C compiler: /home/inkfish/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /home/inkfish/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++
-- Check for working CXX compiler: /home/inkfish/.espressif/tools/xtensa-esp32s2-elf/esp-2020r3-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32s2
-- Project sdkconfig file /mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/sdkconfig
Loading defaults file /mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/sdkconfig.defaults...
/mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/sdkconfig.defaults:237 CONFIG_ESP32S2_MEMPROT_FEATURE was replaced with CONFIG_ESP_SYSTEM_MEMPROT_FEATURE
/mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/sdkconfig.defaults:238 CONFIG_ESP32S2_MEMPROT_FEATURE_LOCK was replaced with CONFIG_ESP_SYSTEM_MEMPROT_FEATURE_LOCK
/mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/sdkconfig.defaults:435 CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE was replaced with CONFIG_ESP_COREDUMP_ENABLE_TO_NONE
-- Found PythonInterp: /home/inkfish/.espressif/python_env/idf4.4_py3.8_env/bin/python (found version "3.8.5")
-- Found Perl: /usr/bin/perl (found version "5.30.0")
-- App "app_main" version: a335f49-dirty
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.api.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.libgcc.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-funcs.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-data.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.spiflash.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/build/esp-idf/esp32s2/esp32s2_out.ld
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp32s2/ld/esp32s2.project.ld.in
-- Adding linker script /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/esp32s2/ld/esp32s2.peripherals.ld
CMake Error at /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/tools/cmake/component.cmake:305 (message):
  Include directory
  '/mnt/g/project/LinuxProjectsDir/esp32/esp-idf/components/nghttp/nghttp2/third-party/http-parser'
  is not a directory.
Call Stack (most recent call first):
  /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/tools/cmake/component.cmake:477 (__component_add_include_dirs)
  /mnt/g/project/LinuxProjectsDir/esp32/esp-idf/tools/cmake/component.cmake:538 (idf_component_register)
  main/CMakeLists.txt:23 (register_component)
-- Configuring incomplete, errors occurred!
See also "/mnt/g/project/LinuxProjectsDir/esp32/esp-dev-kits/esp32-s2-kaluga-1/examples/tago_wifi_s2/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
请问怎么解决
王玲
2024-6-22 15:22:01
看起来您在使用ESP-IDF构建系统时遇到了一些问题。以下是一些建议来解决这个问题:
1. 确保您的ESP-IDF版本是最新的。您可以使用以下命令来克隆或更新ESP-IDF:
git clone https://github.com/espressif/esp-idf.git
cd esp-idf
git checkout master
git pull
2. 确保您的ESP-IDF环境变量已正确设置。在Linux和MacOS上,您可以在`~/.bashrc`或`~/.zshrc`文件中添加以下行:
export PATH="$HOME/esp/esp-idf/tools/idf.py:$PATH"
然后,运行以下命令使更改生效:
source ~/.bashrc
或者,如果您使用的是zsh:
source ~/.zshrc
3. 确保您的ESP-IDF依赖项已正确安装。您可以使用以下命令来安装依赖项:
cd ~/esp/esp-idf
./install.sh
4. 确保您的项目目录结构正确。通常,您的项目应该包含以下结构:
project/
├── components/
├── main/
│   ├── Kconfig.projbuild
│   ├── Makefile.projbuild
│   └── src/
├── sdkconfig
└── sdkconfig.defaults
5. 在项目目录中,运行以下命令来设置目标和配置:
cd /path/to/your/project
idf.py menuconfig
6. 如果问题仍然存在,请尝试清理构建目录并重新构建项目:
idf.py fullclean
idf.py build
希望这些建议能帮助您解决问题。如果问题仍然存在,请提供更多详细信息,以便我们能够更好地帮助您。
