RISC-V技术论坛
廉鼎琮
7年用户 924经验值
pro 35T run_openocd报错的原因?
开发板:达芬奇pro 35T
调试器:SIPEED RV-Debugger plus
run_openocd报错如下:
  • Start openocd server
  • openocd -c “gdb_port 3333” -f ../../../SoC/hbirdv2/Board/ddr200t/openocd_hbirdv2.cfg
  • Nuclei OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev-00036-gbfc178ffb (2021-02-01-06:41)
  • Licensed under GNU GPL v2
  • For bug reports, read
  • http://openocd.org/doc/doxygen/bugs.html
  • Info : Using libusb driver
  • Info : clock speed 1000 kHz
  • Info : JTAG tap: riscv.cpu tap/device found: 0x200a6d01 (mfg: 0x680 (), part: 0x00a6, ver: 0x2)
  • Info : TAP auto0.tap does not have IDCODE
  • Info : JTAG tap: auto1.tap tap/device found: 0xffffff8f (mfg: 0x7c7 (), part: 0xffff, ver: 0xf)
  • Warn : AUTO auto0.tap - use “jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000”
  • Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
  • Warn : Bypassing JTAG setup events due to errors
  • Info : Exposing additional CSR 770
  • Info : Exposing additional CSR 771
  • Info : Exposing additional CSR 775
  • Info : Exposing additional CSR 776
  • Info : Exposing additional CSR 777
  • Info : Exposing additional CSR 778
  • Info : Exposing additional CSR 779
  • Info : Exposing additional CSR 780
  • Info : Exposing additional CSR 781
  • Info : Exposing additional CSR 782
  • Info : Exposing additional CSR 783
  • Info : Exposing additional CSR 784
  • Info : Exposing additional CSR 785
  • Info : Exposing additional CSR 786
  • Info : Exposing additional CSR 787
  • Info : Exposing additional CSR 788
  • Info : Exposing additional CSR 789
  • Info : Exposing additional CSR 790
  • Info : Exposing additional CSR 791
  • Info : Exposing additional CSR 792
  • Info : Exposing additional CSR 793
  • Info : Exposing additional CSR 794
  • Info : Exposing additional CSR 795
  • Info : Exposing additional CSR 796
  • Info : Exposing additional CSR 797
  • Info : Exposing additional CSR 798
  • Info : Exposing additional CSR 799
  • Info : Exposing additional CSR 800
  • Info : Exposing additional CSR 837
  • Info : Exposing additional CSR 838
  • Info : Exposing additional CSR 839
  • Info : Exposing additional CSR 840
  • Info : Exposing additional CSR 841
  • Info : Exposing additional CSR 842
  • Info : Exposing additional CSR 843
  • Info : Exposing additional CSR 844
  • Info : Exposing additional CSR 845
  • Info : Exposing additional CSR 846
  • Info : Exposing additional CSR 847
  • Info : Exposing additional CSR 848
  • Info : Exposing additional CSR 849
  • Info : Exposing additional CSR 850
  • Info : Exposing additional CSR 1984
  • Info : Exposing additional CSR 1985
  • Info : Exposing additional CSR 1986
  • Info : Exposing additional CSR 1987
  • Info : Exposing additional CSR 1988
  • Info : Exposing additional CSR 1989
  • Info : Exposing additional CSR 1990
  • Info : Exposing additional CSR 1991
  • Info : Exposing additional CSR 1992
  • Info : Exposing additional CSR 1993
  • Info : Exposing additional CSR 1994
  • Info : Exposing additional CSR 1995
  • Info : Exposing additional CSR 1996
  • Info : Exposing additional CSR 1997
  • Info : Exposing additional CSR 1998
  • Info : Exposing additional CSR 1999
  • Info : Exposing additional CSR 2000
  • Info : Exposing additional CSR 2001
  • Info : Exposing additional CSR 2002
  • Info : Exposing additional CSR 2003
  • Info : Exposing additional CSR 2004
  • Info : Exposing additional CSR 2005
  • Info : Exposing additional CSR 2006
  • Info : Exposing additional CSR 2007
  • Info : Exposing additional CSR 2008
  • Info : Exposing additional CSR 2009
  • Info : Exposing additional CSR 2010
  • Info : Exposing additional CSR 2011
  • Info : Exposing additional CSR 2012
  • Info : Exposing additional CSR 2013
  • Info : Exposing additional CSR 2014
  • Info : Exposing additional CSR 2015
  • Info : Exposing additional CSR 2016
  • Info : Exposing additional CSR 2017
  • Info : Exposing additional CSR 2018
  • Info : Exposing additional CSR 2019
  • Info : Exposing additional CSR 2020
  • Info : Exposing additional CSR 2021
  • Info : Exposing additional CSR 2022
  • Info : Exposing additional CSR 2023
  • Info : Exposing additional CSR 2024
  • Info : Exposing additional CSR 2025
  • Info : Exposing additional CSR 2026
  • Info : Exposing additional CSR 2027
  • Info : Exposing additional CSR 2028
  • Info : Exposing additional CSR 2029
  • Info : Exposing additional CSR 2030
  • Info : Exposing additional CSR 2031
  • Info : Exposing additional CSR 2032
  • Info : Exposing additional CSR 2064
  • Info : Exposing additional CSR 2065
  • Info : Exposing additional CSR 2066
  • Info : Exposing additional CSR 2067
  • Info : Exposing additional CSR 2068
  • Info : Exposing additional CSR 2069
  • Info : Exposing additional CSR 2070
  • Error: dtmcontrol is 0. Check JTAG connectivity/board power.
  • Info : Listening on port 3333 for gdb connections
  • Error: Target not examined yet
  • make: * [../../../Build/Makefile.rules:107:run_openocd] 错误 1
陈静
2024-5-29 16:09:14
根据您提供的信息,您正在尝试使用OpenOCD调试达芬奇Pro 35T开发板,并使用SIPEED RV-Debugger plus调试器。报错信息如下:
openocd -c "gdb_port 3333" -f ../../../SoC/hbirdv2/Board/ddr200t/openocd_hbirdv2.cfg
从这个报错信息中,我们无法直接看到具体的错误。但是,我们可以从以下几个方面来分析可能的原因:
1. 配置文件路径问题:请确保您提供的配置文件路径是正确的。如果路径错误,OpenOCD可能无法找到配置文件,从而导致问题。
2. 驱动问题:请确保您的系统已经安装了适用于SIPEED RV-Debugger plus调试器的驱动程序。如果没有安装正确的驱动程序,OpenOCD可能无法正确识别和连接调试器。
3. 调试器连接问题:请检查您的调试器是否已经正确连接到开发板,并且连接是否稳定。如果连接不稳定或存在问题,可能会导致OpenOCD无法正常工作。
4. OpenOCD版本问题:您当前使用的OpenOCD版本是0.10.0+dev-00036-gbfc178ffb,这可能是一个开发版本。尝试使用稳定版本的OpenOCD,看看问题是否得到解决。
5. 权限问题:确保您有足够的权限运行OpenOCD。如果没有足够的权限,可能会导致OpenOCD无法正常工作。
为了解决这个问题,您可以尝试以下步骤:
1. 检查配置文件路径是否正确。
2. 确保已经安装了适用于SIPEED RV-Debugger plus调试器的驱动程序。
3. 检查调试器与开发板的连接是否稳定。
4. 尝试使用稳定版本的OpenOCD。
5. 确保您有足够的权限运行OpenOCD。
如果问题仍然存在,请提供更详细的错误信息,以便我们能够更准确地分析问题并提供解决方案。
