王利祥
7年用户 1403经验值
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
我现在在做一个STM32F0的实验,板子的电路图如下,当tiM2开启输出PWM波形后,OLED会变暗,别外一个板子还直接重启,是不是我哪里没有配置好的?找了好久一直没有找到原因,代码和电路图如下:
uint32_t ohm_freq = 238000;
uint16_t  ohm_percent = 500;
void OHM_GPIO_Init(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
        //Charge_PWM GPIO Port
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOB,  GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_2);
        //DIO_Ctrl_Pin
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_ResetBits(GPIOB, GPIO_Pin_14);
void OHM_TIM_PWM_Init(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        uint32_t TimerPeriod = 0;
        uint32_t ChannelPulse = 0;
        TimerPeriod = (SystemCoreClock/ohm_freq)-1;
        ChannelPulse = ohm_percent*(TimerPeriod - 1)/1000;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        TIM_TimeBaseStructure.TIM_Prescaler = 0;  //预分频系数(48-1), t=48/48000000=1us, 即TIMx->CNT每1us加一次
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
        TIM_TimeBaseStructure.TIM_Period = TimerPeriod;//TimerPeriod;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM2,  TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        //TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_Pulse = ChannelPulse;//ChannelPulse;;
        //TIM_OC1Init(TIM2,  TIM_OCInitStructure);
        TIM_OC4Init(TIM2,  TIM_OCInitStructure);
        //放到Enable函数里面
        //TIM_Cmd(TIM2, ENABLE);
        //TIM_CtrlPWMOutputs(TIM2, ENABLE);
void OHM_Chk_Timer_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM16, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel = TIM16_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 0x03;
        NVIC_Init( NVIC_InitStructure);
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_Period = 50; //50ms
        TIM_TimeBaseStructure.TIM_Prescaler = 47999; //分频,1ms计数一次
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x03;
        TIM_TimeBaseInit(TIM16,  TIM_TimeBaseStructure);
        TIM_ClearITPendingBit(TIM16, TIM_IT_Update);
        TIM_ITConfig(TIM16, TIM_IT_Update, ENABLE);
        TIM_Cmd(TIM16, ENABLE);
void OHM_Init(void)
        OHM_GPIO_Init();
        OHM_TIM_PWM_Init();
        OHM_Chk_Timer_Init();
void OHM_Start(void)
        GPIO_SetBits(GPIOB, GPIO_Pin_14);
void OHM_Stop(void)
        TIM_CtrlPWMOutputs(TIM2, DISABLE);
        TIM_Cmd(TIM2, DISABLE);
回帖(3)
李凤璐
2024-4-28 10:40:22
OLED变暗怎么感觉像是电流不够造成的,系统复位重启感觉像是电压不稳,造成的。会不会是你的电路板有问题?
刘悦竹
2024-4-28 10:40:26
怀疑PWM输出有问题的话,可以把输出线切断看看
张琳
2024-4-28 10:40:33
把uint32_t ohm_freq = 238000;改成uint32_t ohm_freq = 90000;就可以正常的了
