嵌入式学习小组
任凭风吹
9年用户 963经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术 制造/封装 模拟技术
M051可以通过ACMP从掉电模式唤醒吗?
* @file     main.c
* @version  V3.00
* $Revision: 2 $
* $Date: 15/05/22 2:58p $
* @brief    Show how to wake up MCU from Power-down mode by ACMP wake-up function.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include
#include "M051Series.h"
/* Function prototype declaration */
void SYS_Init(void);
void PowerDownFunction(void);
int IsDebugFifoEmpty(void);
int32_t main(void)
    uint32_t u32DelayCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O. */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
    UART_Open(UART0, 115200);
    printf("\n\n");
    printf("+---------------------------------------+\n");
    printf("|         M051 ACMP Sample Code         |\n");
    printf("\nThis sample code demonstrates ACMP0 wake-up function. Using ACMP0_P (P1.5) as ACMP0\n");
    printf("positive input and using internal band-gap voltage as the negative input.\n");
    printf("The compare result reflects on ACMP0_O (P3.6).\n");
    printf("When the voltage of the positive input is greater than the voltage of the negative input,\n");
    printf("the analog comparator outputs logical one; otherwise, it outputs logical zero.\n");
    printf("This chip will be waked up from power down mode when detecting a transition of analog comparator's output.\n");
    printf("Press any key to enter power down mode ...");
    getchar();
    printf("\n");
    /* Configure ACMP0. Enable ACMP0 and select internal reference voltage as negative input. */
    ACMP_Open(ACMP01, 0, ACMP_CR_VNEG_BANDGAP, ACMP_CR_HYSTERESIS_DISABLE);
    __NOP();
    for(u32DelayCount = 0; u32DelayCount < 100; u32DelayCount++); /* For ACMP setup time */
    __NOP();
    /* Clear ACMP 0 interrupt flag */
    ACMP_CLR_INT_FLAG(ACMP01, 0);
    /* Enable ACMP0 interrupt function */
    ACMP_ENABLE_INT(ACMP01, 0);
    /* Enable ACMP01 interrupt */
    NVIC_EnableIRQ(ACMP01_IRQn);
    /* To program PWRCTL register, it needs to disable register protection first. */
    SYS_UnlockReg();
    PowerDownFunction();
    printf("Wake up by ACMP0!\n");
    while(1);
void ACMP01_IRQHandler(void)
    printf("\nACMP0 interrupt!\n");
    /* Disable interrupt */
    ACMP_DISABLE_INT(ACMP01, 0);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable external 12MHz XTAL */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Select HXT as the clock source of UART */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Enable UART peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ACMP01 peripheral clock */
    CLK_EnableModuleClock(ACMP01_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CyclesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P1.5 multi-function pin for ACMP0 positive input pin */
    SYS->P1_MFP = SYS_MFP_P15_ACMP0_P;
    /* Disable digital input path of analog pin ACMP0_P to prevent leakage */
    GPIO_DISABLE_DIGITAL_PATH(P1, BIT5);
    /* Set P3 multi-function pins for UART0 RXD, TXD and ACMP0 output */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P36_ACMP0_O;
    printf("\nSystem enter power-down mode ... ");
    /* To check if all the debug messages are finished */
    while(IsDebugFifoEmpty() == 0);
    /* Deep sleep mode is selected */
    SCB->SCR = SCB_SCR_SLEEPDEEP_Msk;
    CLK->PWRCON &= ~(CLK_PWRCON_PD_WAIT_CPU_Msk | CLK_PWRCON_PWR_DOWN_EN_Msk);
    CLK->PWRCON |= (CLK_PWRCON_PD_WAIT_CPU_Msk | CLK_PWRCON_PWR_DOWN_EN_Msk | CLK_PWRCON_PD_WU_INT_EN_Msk);
    __WFI();
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
贺服窍
2024-1-15 15:21:25
可以,该示例代码演示了如何使用ACMP唤醒M051芯片从掉电模式。在该示例中,ACMP输入通道选择为ADC_CH6,引脚选择为P1.5,唤醒模式选择为电平唤醒,即当ACMP输出电平为高时唤醒M051芯片。唤醒后,程序会进入main函数并通过LED进行闪烁。
