我遇到代码空间问题:
代码:
全选mingw32-make.exe -f "C:/Documents and Set
tings/Administrator/My Documents/ESP8266/Boiler/Makefile" all
c:/Espressif/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -Lc:/Espressif/ESP8266_SDK/lib -Tc:/Espressif/ESP8266_SDK/ld/eagle.app.v6.ld -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lat -lnet80211 -llwip -lwpa -lmain -lupgrade -lssl build/app_app.a -Wl,--end-group -o build/app.out
c:/espressif/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: build/app.out section `.irom0.text' will not fit in region `irom0_0_seg'
所以我尝试为链接器设置映射选项。它不喜欢 -Map=file 之类的东西,所以我尝试了 -M
代码:
全选mingw32-make.exe -f "C:/Documents and Settings/Administrator/My Documents/ESP8266/Boiler/Makefile" all
c:/Espressif/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -Lc:/Espressif/ESP8266_SDK/lib -Tc:/Espressif/ESP8266_SDK/ld/eagle.app.v6.ld -M -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lat -lnet80211 -llwip -lwpa -lmain -lupgrade -lssl build/app_app.a -Wl,--end-group -o build/app.out
xtensa-lx106-elf-gcc: warning: build/app_app.a: linker input file unused because linking not done
