我正在创建一个 android 客户端应用程序来与连接到 Arduino 的 ESp8266 进行
通信。我似乎无法让套接字将数据传递给 ESP。我正在使用 Android studio 编写客户端应用程序,在调试时它显示为正在连接的套接字但是当我将数据发送到套接字服务器(ESP8266-01)时我没有收到任何响应并且连接到的串行监视器上没有打印任何内容ESP。附件是我通过 arduino IDE 编程的 ESP 代码。
代码:
全选#include
#include
#include
#include
#include
#include
#include
//ESP8266WiFiMul
ti WiFiMulti;
ESP8266WebServer server = ESP8266WebServer(80);
WebSocketsServer webSocket = WebSocketsServer(81);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[%u] Disconnected!\n", num);
break;
case WStype_CONNECTED: {
IPAddress ip = webSocket.remoteIP(num);
Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// send message to client
webSocket.sendTXT(num, "Connected");
break;
case WStype_TEXT:
Serial.printf("$%s?\n", payload);
webSocket.sendTXT(num, payload,sizeof(payload),false);
break;
void setup() {
//Serial.begin(921600);
Serial.begin(115200);
//Serial.setDebugOutput(true);
Serial.println();
Serial.println();
Serial.println();
for(uint8_t t = 4; t > 0; t--) {
Serial.printf("[SETUP] BOOT WAIT %d...\n", t);
Serial.flush();
delay(1000);
Serial.println("Starting AP");
WiFi.mode(WIFI_AP);
WiFi.softAP("Alpine_SIM_CNTRL","12345678");
Serial.println("AP Started");
//while(WiFiMulti.run() != WL_CONNECTED) {
//delay(100);
//Serial.println("Delayed");
Serial.println("Starting Socket");
// start webSocket server
webSocket.begin();
webSocket.onEvent(webSocketEvent);
Serial.println("Socket Started");
if(MDNS.begin("simcontrol")) {
Serial.println("MDNS responder started");
Serial.println("Starting Server");
//handle index
server.on(
server.send(200,"text/plain","You are connected");
server.begin();
Serial.println("Server Started");
//Add service to MDNS
MDNS.addService("http", "tcp", 80);
MDNS.addService("ws", "tcp", 81);
void loop() {
webSocket.loop();
server.handleClient();
下面是 Android 代码中的异步任务:
代码:
全选public class WriteToServer extends AsyncTask {
Context context;
Socket socket;
public WriteToServer(MyTaskParams Params) {
@Override
protected String doInBackground(MyTaskParams... params) {
socket = null;
DataInputStream in = null;
DataOutputStream out = null;
context = params[0].context;
String command = params[0].cmd;
String response = null;
try {
socket = new Socket("192.168.4.1",81);
out = new DataOutputStream(socket.getOutputStream());
in = new DataInputStream(socket.getInputStream());
out.writeUTF(command);
Log.i("Command","Command sent: " + command);
while(in.available() > 0) {
response = in.readUTF();
} catch (IOException e) {
e.printStackTrace();
Log.e("Error","There was an error writing to the socket. Thrown IO exception");
}finally {
if(socket != null){
try{
Log.i("INFO","closing the socket");
socket.close();
}catch(IOException e){
if(in != null){
try{
in.close();
if(out != null){
try{
out.close();
return response;
几天来我一直在为此苦思冥想,无法弄清楚为什么套接字不向 ESP8266 发送数据,反之亦然。附带说明一下,我将我的 PC 连接到 ESP 并输入 192.168.4.1:81/****,我得到了回复“这只是一个套接字服务器”。所以我知道套接字服务器已启动并正在运行。
