NXP MCU 技术论坛
李泽明
7年用户 1174经验值
为什么无法使用自定义Imx8mn ping?
我有一个安装了 RTL8211FS-CG PHY 的自定义 imx8mn。我可以很好地建立链接,但无法 ping 通。我在 arp 缓存中看到路由器的 mac 地址。但 ping 失败。
&fec1 {
    pinctrl-names = \"默认\" ;
    pinctrl-0 = < &pinctrl_fec1 >;
    phy-mode = \"rgmii-id\" ;
    phy-handle = < ðphy1 >;
    fsl,魔术包;
    phy-reset-gpios = < &gpio1  11  GPIO_ACtiVE_LOW >;
    phy-reset-duration = < 10 >;
    状态= “好的” ;
    音频{
        #address-cells = < 1 >;
        #size-cells = < 0 >;
        ethphy1 :以太网-phy@1 {
            compatible = \"ethernet-phy-ieee802.3-c22\" ;
            reg = < 1 >;
            中断 = < &gpio1  15  IRQ_TYPE_EDGE_FALLING >;
            phy-reset-gpios = < &gpio1  11  GPIO_ACTIVE_LOW >;
            vddio-supply = < &vddio >;
            vddio : vddio 调节器{
                regulator-min-microvolt = < 1800000 >;
                regulator-max-microvolt = < 1800000 >;
    pinctrl_fec1 : fec1grp {
        fsl,引脚 = <
            MX8MN_IOMUXC_ENET_MDC_ENET1_MDC 0x3
            MX8MN_IOMUXC_ENET_MDIO_ENET1_MDIO 0x3
            MX8MN_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f
            MX8MN_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f
            MX8MN_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f
            MX8MN_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f
            MX8MN_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91
            MX8MN_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91
            MX8MN_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91
            MX8MN_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91
            MX8MN_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f
            MX8MN_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91
            MX8MN_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL  0x91
            MX8MN_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL  0x1f
            MX8MN_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x19
            MX8MN_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x19
