NXP MCU 技术论坛
杨帆
7年用户 1352经验值
esp_wifi_init() 期间堆内存不足怎么处理?
我正在使用带有 LVGL 的 ESP32 项目。起点是https://github.com/espressif/esp-dev-ki ... ello_world项目。我想添加 WiFi 接入点功能,但似乎没有足够的可用内存。减小 LVGL 的缓冲区大小,或将其移至 PSRAM 可解决该问题。但这使得显示极其缓慢。我打印了 lvgl 分配的数量、可用内存和 largest_free_block 以确定是否应该有足够的可用内存。“largest free”在调用 esp_wifi_init() 之前打印出来。
我不明白为什么没有足够的可用内存...
代码:全选
allocating =    48000 bytes
heap free =    2162366
largest free = 2064384
I (2245) wifi:wifi driver task: 3fffbabc, prio:23, stack:6656, core=0
I (2245) system_api: Base MAC address is not set
I (2245) system_api: read default base MAC address from EFUSE
I (2248) wifi:wifi firmware version: 6567a16
I (2248) wifi:wifi certification version: v7.0
I (2249) wifi:config NVS flash: enabled
I (2249) wifi:config nano formating: disabled
I (2249) wifi:Init data frame dynamic rx buffer num: 32
I (2249) wifi:Init management frame dynamic rx buffer num: 32
I (2249) wifi:Init management short buffer num: 32
I (2250) wifi:Init static tx buffer num: 16
I (2251) wifi:Init tx cache buffer num: 32
I (2251) wifi:Init static rx buffer size: 1600
W (2251) wifi:malloc buffer fail
I (2251) wifi:Init static rx buffer num: 6
I (2251) wifi:Init dynamic rx buffer num: 32
E (2252) wifi:Expected to init 10 rx buffer, actual is 6
I (2252) wifi:Deinit lldesc rx mblock:0
I (2253) wifi:Deinit lldesc rx mblock:0
I (2254) wifi_init: rx ba win: 6
I (2254) wifi_init: tcpip mbox: 32
I (2254) wifi_init: udp mbox: 6
I (2254) wifi_init: tcp mbox: 6
I (2254) wifi_init: tcp tx win: 5744
I (2254) wifi_init: tcp rx win: 5744
I (2255) wifi_init: tcp mss: 1440
I (2255) wifi_init: WiFi/LWIP prefer SPIRAM
I (2255) wifi_init: WiFi IRAM OP enabled
I (2255) wifi_init: WiFi RX IRAM OP enabled
ESP_ERROR_CHECK failed: esp_err_t 0x101 (ESP_ERR_NO_MEM) at 0x4002e4fc
0x4002e4fc: _esp_error_check_failed at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:42
file: "./components/levelz-ap/levelz-ap.cpp" line 43
func: CLevelzAp::CLevelzAp(const char*, const char*)
expression: esp_wifi_init(&cfg)
abort() was called at PC 0x4002e4ff on core 0
0x4002e4ff: _esp_error_check_failed at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:43
Backtrace: 0x40025b32:0x3ffd5700 0x4002e509:0x3ffd5720 0x40035ede:0x3ffd5740 0x4002e4ff:0x3ffd57b0 0x40087dbd:0x3ffd57d0 0x4008794e:0x3ffd5960 0x4011c4db:0x3ffd5980 0x40031045:0x3ffd59a0
0x40025b32: panic_abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/panic.c:408
0x4002e509: esp_system_abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_system.c:137
0x40035ede: abort at C:/Espressif/frameworks/esp-idf-v4.4.4/components/newlib/abort.c:46
0x40087dbd: CLevelzAp::CLevelzAp(char const*, char const*) at C:/Users/Luc/websites/harmonic-design/levelz-touch/components/levelz-ap/levelz-ap.cpp:43 (discriminator 1)
0x4008794e: app_main at C:/Users/Luc/websites/harmonic-design/levelz-touch/main/main.cpp:44
0x4011c4db: main_task at C:/Espressif/frameworks/esp-idf-v4.4.4/components/freertos/port/port_common.c:141 (discriminator 2)
0x40031045: vPortTaskWrapper at C:/Espressif/frameworks/esp-idf-v4.4.4/components/freertos/port/xtensa/port.c:142
ELF file SHA256: 03268c16eaf653df
CPU halted.
