NXP MCU 技术论坛
高桂清
7年用户 988经验值
为SAI3和SPDIF模块提供根时钟的外部时钟冻结系统怎么解决?
嗨,
我正在尝试在 iMX8MM 的 CLK_EXT3 Ball AG11 上使用 22579200 Hz 的外部时钟
这个时钟应该为 SAI3 和 SPDIF 模块提供时钟
不幸的是,一旦它尝试更改时钟父级,电路板就会冻结
这非常接近线程:
这是我的相关 dts 声明:
时钟 {
    clk_ext3: clock@4 {
        compatible = "fixed-clock";
        注册 = <5>;
        #clock-cells = <0>;
        时钟频率 = <22579200>;
        时钟输出名称=“clk_ext3”;
    captina: captina {
        compatible = "cp,captina";
        #sound-dai-cells = <0>;/* simple-card needs */
        clocks = <&clk IMX8MM_CLK_SAI3_ROOT>;
        时钟名称=“mclk”;
    sound-captina {
        compatible = "simple-audio-card";
        simple-audio-card,name = "captina Card";
        简单音频卡,格式=“i2s”;
        simple-audio-card,frame-master = <&dailink0_master>;
        /* 左右声道切换 */
        simple-audio-card,frame-inversion;
        simple-audio-card,widgets =
            "Line", "Line Out Jack",
            "Line", "Line In Jack";
        simple-audio-card,routing =
            "Line Out Jack", "LOUT",
            "Line Out Jack", "ROUT",
            "LIN", "Line In Jack",
            "RIN", "Line In Jack";
        dailink0_master: simple-audio-card,cpu {
            sound-dai = <&sai3>;
            dai-tdm-slot-num = <2>;
            dai-tdm-slot-width = <32>;
        简单音频卡,编解码器{
            sound-dai = <&captina>;
            时钟=<&clk IMX8MM_CLK_SAI3_ROOT>;
            时钟名称=“mclk”;
    sound-spdif {
        compatible = "fsl,imx-audio-spdif";
        型号 = “imx-spdif”;
        spdif-controller = <&spdif1>;
        spdif 输出;
        spdif 输入;
pinctrl_sai3: sai3grp {
    fsl,pins = <
        MX8MM_IOMUXC_SAI3_TXFS_SAI3_TX_SYNC 0xd6
        MX8MM_IOMUXC_SAI3_TXD_SAI3_TX_DATA0 0xd6
        MX8MM_IOMUXC_SAI3_TXC_SAI3_TX_BCLK 0xd6
         * RXFS 也必须是三态,因为 TXFS 也必须在同一线路上播放
        MX8MM_IOMUXC_SAI3_RXFS_GPIO4_IO28      0x19
        MX8MM_IOMUXC_SAI3_RXD_SAI3_RX_DATA0    0xd6
        MX8MM_IOMUXC_SAI3_RXC_SAI3_RX_BCLK     0xd6
        /* MCLK input from oscillator */
        MX8MM_IOMUXC_GPIO1_IO06_CCMSRCGPCMIX_EXT_CLK3  0x00000011
&sai3 {
    pinctrl-names = "默认";
    pinctrl-0 = <&pinctrl_sai3>;
    assigned-clocks = <&clk IMX8MM_CLK_SAI3>;
    指定时钟父母=<&clk IMX8MM_CLK_EXT3>;
    分配的时钟速率 = <22579200>;
    状态=“好的”;
&spdif1 {
    pinctrl-names = "
    pinctrl-0 = <&pinctrl_spdif1>;
    分配时钟=<&clk IMX8MM_CLK_SPDIF1>;
    clocks = <&clk IMX8MM_CLK_AUDIO_AHB>, <&clk IMX8MM_CLK_24M>,
        <&clk IMX8MM_CLK_SPDIF1>, <&clk IMX8MM_CLK_DUMMY>,
        <&clk IMX8MM_CLK_DUMMY>, <&clk IMX8MM_CLK_DUMMY>,
        <&clk IMX8MM_CLK_AUDIO_AHB>, <&clk IMX8MM_CLK_DUMMY>,
        <&clk IMX8MM_CLK_DUMMY>, <&clk IMX8MM_CLK_DUMMY >,
        <&clk IMX8MM_AUDIO_PLL1_OUT>, <&clk IMX8MM_AUDIO_PLL2_OUT>;
    时钟名称=“核心”,“
当 sai3 和 spdif 有这样的指定时钟父母时:
分配时钟父母=<&clk IMX8MM_AUDIO_PLL2_OUT>;
系统没有冻结,但它们在 clk_ext3 上不同步
