乐鑫技术交流
康辅佑
8年用户 1045经验值
擅长:控制/MCU
.clk_src上的gptimer配置错误问题如何解决?
我已经将我的代码从 ESP-IDF 4.3 更新到 5.0,其中一个变化是通用定时器,我正在尝试在自定义项目上使用定时器,它会构建并闪烁,但是当我打开时我在显示器上收到这个错误。
代码:全选
0x4012a555: timer_ll_set_clock_prescale at /home/vendpago/esp/esp-idf/components/hal/esp32/include/hal/timer_ll.h:68
(inlined by) gptimer_select_periph_clock at /home/vendpago/esp/esp-idf/components/driver/gptimer.c:480
0x4012a8ab: gptimer_new_timer at /home/vendpago/esp/esp-idf/components/driver/gptimer.c:184 (discriminator 2)
0x400d9229: init_timer0 at /home/vendpago/esp/PayBluEsp/main/Timers.c:215
0x400d93e2: app_main_timer at /home/vendpago/esp/PayBluEsp/main/Timers.c:272 (discriminator 13)
这是 init_timer0 的代码:
代码:全选
void init_timer0(){
    ESP_LOGI(TAGtimer, "Create timer handle");
    gptimer_handle_t gptimer0 = NULL;
    gptimer_config_t timer_config = {
        .clk_src = GPTIMER_CLK_SRC_APB,
        .direction = GPTIMER_COUNT_UP,
        .resolution_hz = 1000, // 1kHz, 1 tick=1ms
    ESP_ERROR_CHECK(gptimer_new_timer(&timer_config, &gptimer0));
    gptimer_event_callbacks_t cbs = {
        .on_alarm = timer_group0_isr, // register user callback
    ESP_ERROR_CHECK(gptimer_register_event_callbacks(gptimer0, &cbs, timer_queue));
    ESP_ERROR_CHECK(gptimer_enable(gptimer0));
    gptimer_alarm_config_t alarm_config = {
        .reload_count = 0, // counter will reload with 0 on alarm event
        .alarm_count = TIMER_INTERVAL0_SEC, // period = 1249ms @resolution 1kHz
        .flags.auto_reload_on_alarm = true, // enable auto-reload
    ESP_ERROR_CHECK(gptimer_set_alarm_action(gptimer0, &alarm_config));
    ESP_ERROR_CHECK(gptimer_start(gptimer0));
我尝试使用 GPTIMER 中的示例代码,它完美地工作。
