乐鑫技术交流
徐伟
8年用户 972经验值
esp-idf 5.0升级后的编译问题求解
以前用的 idf4.4 编译的,今天升级5.0 后出现这样的问题:
OJECT_VER.
-- Building ESP-IDF components for target esp32c3
-- Project sdkconfig file H:/esp32test/esp32c3_test/template-app/sdkconfig
CMake Error at H:/esp-idf/tools/cmake/crosstool_version_check.cmake:37 (message):
  Toolchain:
  C:/Users/xy/.espressif/tools/riscv32-esp-elf/1.24.0.123_64eb9ff-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe,
  crosstool-ng version 1.24.0.123_64eb9ff doesn't match supported version
  esp-2021r2-patch3
  Please try to run 'idf.py fullclean' to solve it quickly.
  Check Getting Started documentation if the error continues.
  You can override this error and proceed with build by defining the
  IDF_MAINTAINER environment variable.
Call Stack (most recent call first):
  H:/esp-idf/components/esp_common/project_include.cmake:7 (crosstool_version_check)
  H:/esp-idf/tools/cmake/build.cmake:324 (include)
  H:/esp-idf/tools/cmake/build.cmake:537 (__build_process_project_includes)
  H:/esp-idf/tools/cmake/project.cmake:422 (idf_build_process)
  CMakeLists.txt:6 (project)
-- Configuring incomplete, errors occurred!
See also "H:/esp32test/esp32c3_test/template-app/build/CMakeFiles/CMakeOutput.log".
See also "H:/esp32test/esp32c3_test/template-app/build/CMakeFiles/CMakeError.log".
cmake failed with exit code 1
