乐鑫技术交流
麻酱
8年用户 1223经验值
擅长:MEMS/传感技术
使用ESP32C3,用ESP-IDF编译bt_hid_mouse_device例程失败报错如何解决?
补充:配置为esp32,是可以编译成功的,而在设置为esp32s3和esp32c3之后编译会出现以下报错(编译bt_hid_mouse_device例程)。而在使用其他例程是可以编译成功并烧录到esp32c3的(如hello_world/ble_hid_device_demo等例程)
请问有哪位大佬知道这是什么问题吗?
编译信息如下:
Code: Select all
> Executing task: cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 .. <
-- Found Git: E:/Espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: E:/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: E:/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Building ESP-IDF components for target esp32c3
-- Project sdkconfig file C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/sdkconfig
Loading defaults file C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/sdkconfig.defaults...
-- Found PythonInterp: E:/Espressif/python_env/idf4.4_py3.8_env/Scripts/python.exe (found version "3.8.7")
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "bt_hid_mouse_device" version: 1
-- Adding linker script C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/build/esp-idf/esp_system/ld/memory.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_system/ld/esp32c3/sections.ld.in
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.api.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.libgcc.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.newlib.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.version.ld
-- Adding linker script E:/Esp/esp-idf/components/esp_rom/esp32c3/ld/esp32c3.rom.eco3.ld
-- Adding linker script E:/Esp/esp-idf/components/soc/esp32c3/ld/esp32c3.peripherals.ld
-- Components: app_trace app_update asio bootloader bootloader_support bt cbor cmock coap console cxx driver efuse esp-tls esp32c3 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_hid esp_http_client esp_http_server esp_https_ota
esp_https_server esp_hw_support esp_ipc esp_lcd esp_local_ctrl esp_netif esp_phy esp_pm esp_ringbuf esp_rom esp_serial_slave_link esp_system esp_timer esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos hal heap idf_test ieee802154 jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl openthread partition_table protobuf-c protocomm pthread riscv sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter tinyusb unity usb vfs wear_levelling wifi_provisioning wpa_supplicant
-- Component paths: E:/Esp/esp-idf/components/app_trace E:/Esp/esp-idf/components/app_update E:/Esp/esp-idf/components/asio E:/Esp/esp-idf/components/bootloader E:/Esp/esp-idf/components/bootloader_support E:/Esp/esp-idf/components/bt E:/Esp/esp-idf/components/cbor E:/Esp/esp-idf/components/cmock E:/Esp/esp-idf/components/coap E:/Esp/esp-idf/components/console E:/Esp/esp-idf/components/cxx E:/Esp/esp-idf/components/driver E:/Esp/esp-idf/components/efuse E:/Esp/esp-idf/components/esp-tls E:/Esp/esp-idf/components/esp32c3 E:/Esp/esp-idf/components/esp_adc_cal E:/Esp/esp-idf/components/esp_common E:/Esp/esp-idf/components/esp_eth E:/Esp/esp-idf/components/esp_event E:/Esp/esp-idf/components/esp_gdbstub E:/Esp/esp-idf/components/esp_hid E:/Esp/esp-idf/components/esp_http_client E:/Esp/esp-idf/components/esp_http_server E:/Esp/esp-idf/components/esp_https_ota E:/Esp/esp-idf/components/esp_https_server E:/Esp/esp-idf/components/esp_hw_support E:/Esp/esp-idf/components/esp_ipc E:/Esp/esp-idf/components/esp_lcd E:/Esp/esp-idf/components/esp_local_ctrl E:/Esp/esp-idf/components/esp_netif E:/Esp/esp-idf/components/esp_phy E:/Esp/esp-idf/components/esp_pm E:/Esp/esp-idf/components/esp_ringbuf E:/Esp/esp-idf/components/esp_rom E:/Esp/esp-idf/components/esp_serial_slave_link E:/Esp/esp-idf/components/esp_system E:/Esp/esp-idf/components/esp_timer E:/Esp/esp-idf/components/esp_websocket_client E:/Esp/esp-idf/components/esp_wifi E:/Esp/esp-idf/components/espcoredump E:/Esp/esp-idf/components/esptool_py E:/Esp/esp-idf/components/expat E:/Esp/esp-idf/components/fatfs E:/Esp/esp-idf/components/freemodbus E:/Esp/esp-idf/components/freertos E:/Esp/esp-idf/components/hal E:/Esp/esp-idf/components/heap E:/Esp/esp-idf/components/idf_test E:/Esp/esp-idf/components/ieee802154 E:/Esp/esp-idf/components/jsmn E:/Esp/esp-idf/components/json E:/Esp/esp-idf/components/libsodium E:/Esp/esp-idf/components/log E:/Esp/esp-idf/components/lwip C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/main E:/Esp/esp-idf/components/mbedtls E:/Esp/esp-idf/components/mdns E:/Esp/esp-idf/components/mqtt E:/Esp/esp-idf/components/newlib E:/Esp/esp-idf/components/nghttp E:/Esp/esp-idf/components/nvs_flash E:/Esp/esp-idf/components/openssl E:/Esp/esp-idf/components/openthread E:/Esp/esp-idf/components/partition_table E:/Esp/esp-idf/components/protobuf-c E:/Esp/esp-idf/components/protocomm E:/Esp/esp-idf/components/pthread E:/Esp/esp-idf/components/riscv E:/Esp/esp-idf/components/sdmmc E:/Esp/esp-idf/components/soc E:/Esp/esp-idf/components/spi_flash E:/Esp/esp-idf/components/spiffs E:/Esp/esp-idf/components/tcp_transport E:/Esp/esp-idf/components/tcpip_adapter E:/Esp/esp-idf/components/tinyusb E:/Esp/esp-idf/components/unity E:/Esp/esp-idf/components/usb E:/Esp/esp-idf/components/vfs E:/Esp/esp-idf/components/wear_levelling E:/Esp/esp-idf/components/wifi_provisioning E:/Esp/esp-idf/components/wpa_supplicant
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/build
> Executing task: ninja  <
[3/1257] Generating ../../partition_table/partition-table.bin
Partition table binary generated. Contents:
# ESP-IDF Partition Table
# Name, Type, SubType, Offset, Size, Flags
nvs,data,nvs,0x9000,24K,
phy_init,data,phy,0xf000,4K,
factory,app,factory,0x10000,1M,
[437/1257] Performing configure step for 'bootloader'
-- The ASM compiler identification is GNU
-- Found assembler: E:/Espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/riscv32-esp-elf-gcc.exe
-- Adding linker script E:/Esp/esp-idf/components/bootloader/subproject/main/ld/esp32c3/bootloader.ld
-- Adding linker script E:/Esp/esp-idf/components/bootloader/subproject/main/ld/esp32c3/bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp32c3 esp_common esp_hw_support esp_rom esp_system esptool_py freertos hal log main micro-ecc newlib partition_table riscv soc spi_flash
-- Component paths: E:/Esp/esp-idf/components/bootloader E:/Esp/esp-idf/components/bootloader_support E:/Esp/esp-idf/components/efuse E:/Esp/esp-idf/components/esp32c3 E:/Esp/esp-idf/components/esp_common E:/Esp/esp-idf/components/esp_hw_support E:/Esp/esp-idf/components/esp_rom E:/Esp/esp-idf/components/esp_system E:/Esp/esp-idf/components/esptool_py E:/Esp/esp-idf/components/freertos E:/Esp/esp-idf/components/hal E:/Esp/esp-idf/components/log E:/Esp/esp-idf/components/bootloader/subproject/main E:/Esp/esp-idf/components/bootloader/subproject/components/micro-ecc E:/Esp/esp-idf/components/newlib E:/Esp/esp-idf/components/partition_table E:/Esp/esp-idf/components/riscv E:/Esp/esp-idf/components/soc E:/Esp/esp-idf/components/spi_flash
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/build/bootloader
[560/1257] Performing build step for 'bootloader'
[1/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/soc_include_legacy_warn.c.obj
[2/88] Generating project_elf_src_esp32c3.c
[3/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/lldesc.c.obj
[4/88] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/mpu_hal.c.obj
[5/88] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/cpu_hal.c.obj
[6/88] Building C object esp-idf/hal/CMakeFiles/__idf_hal.dir/wdt_hal_iram.c.obj
[7/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/dedic_gpio_periph.c.obj
[8/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/adc_periph.c.obj
[9/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/ledc_periph.c.obj
[10/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/spi_periph.c.obj
[11/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/rmt_periph.c.obj
[12/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/gpio_periph.c.obj
[13/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/gdma_periph.c.obj
[14/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/interrupts.c.obj
[15/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/uart_periph.c.obj
[16/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/timer_periph.c.obj
[17/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/sigmadelta_periph.c.obj
[18/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/i2c_periph.c.obj
[19/88] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32c3/i2s_periph.c.obj
[20/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_init.c.obj
[21/88] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/esp32c3/spi_flash_rom_patch.c.obj
[22/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common_loader.c.obj
[23/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[24/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random_esp32c3.c.obj
[25/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_mem.c.obj
[26/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj[27/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[28/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[29/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/secure_boot.c.obj
[30/88] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/uECC_verify_antifault.c.obj
[31/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[32/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj[33/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[34/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock_loader.c.obj
[35/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[36/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj[37/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console.c.obj
[38/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_console_loader.c.obj
[39/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_efuse_esp32c3.c.obj
[40/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_panic.c.obj[41/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32c3/bootloader_sha.c.obj
[42/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config_esp32c3.c.obj
[43/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32c3/bootloader_soc.c.obj
[44/88] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src_esp32c3.c.obj
[45/88] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32c3/bootloader_esp32c3.c.obj
[46/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32c3/esp_efuse_fields.c.obj
[47/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api_key_esp32xx.c.obj
[48/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[49/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32c3/esp_efuse_rtc_calib.c.obj
[50/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32c3/esp_efuse_utility.c.obj
[51/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32c3/esp_efuse_table.c.obj
[52/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[53/88] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[54/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_clk_init.c.obj
[55/88] Building C object esp-idf/esp_common/CMakeFiles/__idf_esp_common.dir/src/esp_err_to_name.c.obj
[56/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_pm.c.obj
[57/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/cpu_util_esp32c3.c.obj
[58/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_init.c.obj
[59/88] Building C object esp-idf/esp_system/CMakeFiles/__idf_esp_system.dir/esp_err.c.obj
[60/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/compare_set.c.obj
[61/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/cpu_util.c.obj
[62/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_clk.c.obj
[63/88] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_crc.c.obj
[64/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/chip_info.c.obj
[65/88] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_tjpgd.c.obj
[66/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_time.c.obj
[67/88] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_uart.c.obj
[68/88] Building C object esp-idf/esp_hw_support/CMakeFiles/__idf_esp_hw_support.dir/port/esp32c3/rtc_sleep.c.obj
[69/88] Building C object esp-idf/esp_rom/CMakeFiles/__idf_esp_rom.dir/patches/esp_rom_sys.c.obj
[70/88] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_noos.c.obj
[71/88] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log_buffers.c.obj
[72/88] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[73/88] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[74/88] Linking C static library esp-idflogliblog.a
[75/88] Linking C static library esp-idfesp_romlibesp_rom.a
[76/88] Linking C static library esp-idfesp_commonlibesp_common.a
[77/88] Linking C static library esp-idfesp_hw_supportlibesp_hw_support.a
[78/88] Linking C static library esp-idfesp_systemlibesp_system.a
[79/88] Linking C static library esp-idfefuselibefuse.a
[80/88] Linking C static library esp-idfbootloader_supportlibbootloader_support.a
[81/88] Linking C static library esp-idfspi_flashlibspi_flash.a
[82/88] Linking C static library esp-idfmicro-ecclibmicro-ecc.a
[83/88] Linking C static library esp-idfsoclibsoc.a
[84/88] Linking C static library esp-idfhallibhal.a
[85/88] Linking C static library esp-idfmainlibmain.a
[86/88] Linking C executable bootloader.elf
[87/88] Generating binary image from built executable
esptool.py v3.2-dev
Merged 1 ELF section
Generated C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/build/bootloader/bootloader.bin
[88/88] cmd.exe /C "cd /D C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuildbootloaderesp-idfesptool_py && E:Espressifpython_envidf4.4_py3.8_envScriptspython.exe E:/Esp/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x0 C:/Users/Administrator/Desktop/esp32c3/bt_hid_mouse_device/build/bootloader/bootloader.bin"
Bootloader binary size 0x4d80 bytes. 0x3280 bytes (39%) free.
[1255/1257] Linking CXX executable bt_hid_mouse_device.elf
FAILED: bt_hid_mouse_device.elf
cmd.exe /C "cd . && E:Espressiftoolsriscv32-esp-elfesp-2021r2-patch2-8.4.0riscv32-esp-elfbinriscv32-esp-elf-g++.exe -march=rv32imc -nostartfiles -march=rv32imc --specs=nosys.specs @CMakeFilesbt_hid_mouse_device.elf.rsp -o bt_hid_mouse_device.elf  && cd ."
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `esp_bt_gap_cb':
C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:166: undefined reference to `esp_bt_gap_pin_reply'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:174: undefined reference to `esp_bt_gap_pin_reply'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `check_report_id_type':
C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:56: undefined reference to `esp_bt_hid_device_report_error'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:54: undefined reference to `esp_bt_hid_device_report_error'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `send_mouse':
C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:72: undefined reference to `esp_bt_hid_device_send_report'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:77: undefined reference to `esp_bt_hid_device_send_report'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `esp_bt_hidd_cb':
C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:241: undefined reference to `esp_bt_gap_set_scan_mode'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:244: undefined reference to `esp_bt_hid_device_connect'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:230: undefined reference to `esp_bt_hid_device_register_app'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:266: undefined reference to `esp_bt_gap_set_scan_mode'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:283: undefined reference to `esp_bt_gap_set_scan_mode'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:305: undefined reference to `esp_bt_hid_device_send_report'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:307: undefined reference to `esp_bt_hid_device_send_report'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:340: undefined reference to `esp_bt_gap_set_scan_mode'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: esp-idf/main/libmain.a(main.c.obj): in function `app_main':
C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:387: undefined reference to `esp_bt_gap_register_callback'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:406: undefined reference to `esp_bt_gap_set_cod'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:413: undefined reference to `esp_bt_hid_device_register_callback'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:416: undefined reference to `esp_bt_hid_device_init'
e:/espressif/tools/riscv32-esp-elf/esp-2021r2-patch2-8.4.0/riscv32-esp-elf/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:UsersAdministratorDesktopesp32c3bt_hid_mouse_devicebuild/../main/main.c:416: undefined reference to `esp_bt_gap_set_pin'
collect2.exe: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
终端进程“C:WindowsSystem32WindowsPowerShellv1.0powershell.exe -Command ninja ”已终止,退出代码: 1。
