根据手册访问ftp://58.250.18.138 获取资料,我电脑的Explorer访问ftp://58.250.18.138 访问不了,所以用FileZilla来远程访问FTP服务器。
使用FileZilla来访问FTP服务器:
连接成功,因为我申请的是N32G457这款单片机,所以资料是放在2-Microcontrollers里面,然后就是漫长的下载过程。。。。
这里需要用到两个python的包:
compiledb
用于导出 compile_commands.json
来支持补全pyocd
用于启动一个 gdbserver直接pip一键安装即可 pip install compiledb pyocd
在工程目录下创建 pyocd.yaml
来指定 pack 包的位置
pack:
- ./tools/Nationstech.N32G45x_DFP.1.0.5.pack
运行一行命令来查看N32的pack是否导入成功 pyocd list --targets | grep n32g457
将官方给出的vscode示例工程文件复制到本目录,一番整理后工程目录如下
相对应的 Makefile脚本也需要修改,修改后的内容如下:
# [url=home.php?mod=space&uid=1455510]@file[/url] Makefile (based on gcc)
# [url=home.php?mod=space&uid=40524]@author[/url] Dewin
# [url=home.php?mod=space&uid=644434]@version[/url] v1.0.0
# ChangeLog :
# 2021-07-20
# target
TARGET = output
# building variables
# debug build
ifeq ($(release), y)
DEBUG = 0
else
DEBUG = 1
endif
# optimization
OPT = -Os
# Build path
BUILD_DIR = build
# chip platform info
TARGET_PLATFORM := n32g45x
DEFS += -DN32G45X
DEFS += -DUSE_STDPERIPH_DRIVER
# Algo libs
USELIB = 0
#TOOLS CHAIN
CROSS_COMPILE = arm-none-eabi-
#PATH DEFINE
CODE_PATH = code
BSP_PATH = bsp
FIRMWARE_PATH = firmware
# C sources
C_DIRS += ${CODE_PATH}/src
C_DIRS += ${BSP_PATH}/src
C_DIRS += ${FIRMWARE_PATH}/CMSIS/device
C_DIRS += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_std_periph_driver/src
#C_DIRS += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_usbfs_driver/src
SRC_OBJS_DIRS += $(foreach DIR, $(C_DIRS), $(wildcard $(DIR)/*.c))
C_SOURCES = $(SRC_OBJS_DIRS)
# ASM sources
ASM_SOURCES = ${FIRMWARE_PATH}/CMSIS/device/startup/startup_$(TARGET_PLATFORM)_gcc.s
# C includes
C_INCS += ${CODE_PATH}/inc
C_INCS += ${BSP_PATH}/inc
C_INCS += ${FIRMWARE_PATH}/CMSIS/core
C_INCS += ${FIRMWARE_PATH}/CMSIS/device
C_INCS += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_std_periph_driver/inc
#C_INCS += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_usbfs_driver/inc
INCS_OBJS_DIR = $(foreach DIR2, $(C_INCS), $(wildcard $(DIR2)/*.h))
INCS_OBJS_PATH = $(sort $(dir $(INCS_OBJS_DIR)))
C_INCLUDES = $(addprefix -I,$(INCS_OBJS_PATH))
# Lib files
ifeq ($(USELIB), 1)
SRC_LIB_DIR += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_algo_lib/src
INC_LIB_DIR += ${FIRMWARE_PATH}/$(TARGET_PLATFORM)_algo_lib/inc
LIB_SOURCES = $(foreach DIR3, $(SRC_LIB_DIR), $(wildcard $(DIR3)/*.lib))
LIB_SOURCES_L = $(addprefix -L,$(LIB_SOURCES))
C_LIBS = $(LIB_SOURCES_L)
LIB_INCS = $(foreach DIR4, $(INC_LIB_DIR), $(wildcard $(DIR4)/*.h))
LIB_INCS_PATH = $(sort $(dir $(LIB_INCS)))
LIB_INCS_PATH_I = $(addprefix -I,$(LIB_INCS_PATH))
C_INCLUDES += $(LIB_INCS_PATH_I)
endif
# Compile & Link flags
# cpu
CPU = -mcpu=cortex-m4
# fpu
FPU = -mfpu=fpv4-sp-d16
# float-abi
FLOAT-ABI = -mfloat-abi=hard
# mcu
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
#CFLAGS
CFLAGS += $(MCU) -Wall
CFLAGS += $(OPT)
CFLAGS += -ffunction-sections -fdata-sections
#DEBUG
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
#LFLAGS
LFLAGS += $(MCU)
LFLAGS += -Wl,--gc-sections
LFLAGS += --specs=nosys.specs
LFLAGS += -Xlinker -Map=$(BUILD_DIR)/$(TARGET).map
# link script
LDSCRIPT = ${FIRMWARE_PATH}/CMSIS/device/$(TARGET_PLATFORM)_flash.ld
# Objects
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
$(CROSS_COMPILE)gcc $(CFLAGS) $(DEFS) $(C_INCLUDES) $(C_LIBS) -c -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) $< -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
$(CROSS_COMPILE)gcc $(CFLAGS) -c $< -o $@
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
$(CROSS_COMPILE)gcc $(OBJECTS) $(LFLAGS) -T$(LDSCRIPT) -o $@
$(CROSS_COMPILE)size $@
$(BUILD_DIR)/$(TARGET).bin: $(BUILD_DIR)/$(TARGET).elf
$(CROSS_COMPILE)objcopy -O binary -S $< $@
$(BUILD_DIR)/$(TARGET).hex: $(BUILD_DIR)/$(TARGET).elf
$(CROSS_COMPILE)objcopy -O ihex -S $< $@
$(BUILD_DIR):
@-mkdir $@
# clean up
clean:
@-rm -rf $(BUILD_DIR)
# dependencies
-include $(wildcard $(BUILD_DIR)/*.d)
download:
@pyocd flash --target=N32G457VEL7 --erase=auto --frequency=1000000 .\build\output.bin
@echo "Download Completed!"
db:
@compiledb make -j8 all
# *** EOF ***
运行 make db
命令,导出 compile_commands.json
文件,并且移动到 build目录
编写最重要的 Demo.code-workspace
文件:
"folders": [
"path": "."
"settings": {
/* 文件排除 */
"files.exclude": {
// 文件夹
"**/.settings": true,
"**/Debug": true,
"**/Objects": true,
"**/objects": true,
"**/Listings": true,
"**/listings": true,
"**/Output": true,
"**/output": true,
// 文件
"**/*.map": true,
"**/.config*": true,
"**/.project*": true,
"**/.cproject*": true,
"**/*.POMIN": true,
".gitattributes": true
/* 编码 */
"files.encoding": "utf8",
/* 字体 */
"editor.fontFamily": "Consolas, OPPOSans",
/* 自定义 Shell */
"terminal.integrated.profiles.windows": {},
/* 默认 Shell */
"terminal.integrated.defaultProfile.windows": "PowerShell",
/* 代码风格 */
"C_Cpp.formatting": "clangFormat",
"C_Cpp.clang_format_style": "{ BasedOnStyle: Google, IndentWidth: 4 }",
/* 补全模式 */
"C_Cpp.default.intelliSenseMode": "gcc-x86",
/* c/cpp 标准 */
"C_Cpp.default.cppStandard": "c++14",
"C_Cpp.default.cStandard": "c99",
/* c/cpp 宏 */
"C_Cpp.default.defines": [],
"C_Cpp.default.compilerPath": "D:/Maker/Console/arm-gcc/bin/arm-none-eabi-gcc.exe",
/* c/cpp 包含 */
"C_Cpp.default.includePath": ["${workspaceFolder}/**"],
"C_Cpp.default.forcedInclude": [],
"C_Cpp.default.compileCommands": "${workspaceFolder}/build/compile_commands.json",
"cortex-debug.variableUseNaturalFormat": false,
"files.associations": {
"tasks": {
"version": "2.0.0",
"tasks": [
"label": "build",
"type": "shell",
/* 命令 & 参数 */
"command": ["make"],
"args": ["-j8", "all"]
"launch": {
"version": "0.2.0",
"configurations": [
/* launch 任务名字 */
"name": "N32 pyocd dbg",
/* cortex-debug */
"type": "cortex-debug",
/* 工作目录 */
"cwd": "${workspaceRoot}",
/* 调试对象 */
"executable": "./build/output.elf",
/* 请求种类 */
"request": "launch",
/* 入口点 */
"runToEntryPoint": "main",
/* 服务器种类 */
"servertype": "pyocd",
/* 目标芯片 */
"targetId": "n32g457vel7",
/* svd 路径 */
"svdFile": "./tools/N32G457.svd",
"showDevDebugOutput": "both",
/* 预执行任务 */
"preLaunchTask": "build",
/* pack 包目录 */
"cmsisPack": "./tools/Nationstech.N32G45x_DFP.1.0.5.pack"
重启vscode,完美补全
完美 debug,在SRAM基址偏移100KB的位置写入字符串,在memory窗口显示
