ARM技术论坛
王鑫
7年用户 1136经验值
[经验]
浅析System configuration系统配置
Root FS skeleton:
System hostname:填写JZ2440
System banner
Passwords encoding
Init system:系统初始化,选择 BusyBox
/dev management:设备文件管理,选择Dynamic using devtmpfs + mdev,即使用mdev动态加载设备节点的方式
Path to the permission tables:设备节点的配置表设置,一定要选择system/device_table_dev.txt,否则后面在dev目录下将不会生成各种设备节点。当然我们也可以手动的配置该文件,添加必要的节点或删除不需要的节点。
support extended attributes in device tables
Use symlinks to /usr for /bin, /sbin and /lib
Enable root login with password
Root password:进入linux控制台终端后的密码,为空则登录时不需要密码,默认登录用户名为root。为空。
/bin/sh (busybox' default shell)
Run a getty (login prompt) after boot:保持默认,默认为选中。
TTY port:配置为 ttySAC3
Baudrate :波特率,配置为 115200
TERM environment variable:默认即可
other options to pass to getty:默认即可
remount root filesystem read-write during boot
Network interface to configure through DHCP
Purge unwanted locales
Locales to keep
Generate locale data
Install timezone info
Path to the users tables
Root filesystem overlay directories:
Custom scripts to run before creating filesystem images
Custom scripts to run inside the fakeroot environment
Custom scripts to run after creating filesystem images
原作者:DMCF
