WCH沁恒单片机
李浯
8年用户 1107经验值
唤醒事件屏蔽掉RTC,为啥RTC还是能唤醒休眠?
//使能按键和rtc唤醒
if(0/*gTask_Ctrl.Long_Key_Pwr_Off == 0*/)
// wake_event|=RB_SLP_RTC_WAKE;
else
PWR_PeriphWakeUpCfg( DISABLE, RB_SLP_RTC_WAKE, Edge_LongDelay );
PWR_PeriphWakeUpCfg( DISABLE, RB_SLP_BAT_WAKE, Level_ShortDelay );
PWR_PeriphWakeUpCfg( ENABLE, RB_SLP_GPIO_WAKE, Level_LongDelay );
/*请io中断标记*/
R16_PA_INT_IF = 0XFFFF;
R16_PB_INT_IF = 0XFFFF;
/*清掉rtc中断标记*/
R8_RTC_FLAG_CTRL = ( RB_RTC_TMR_CLR | RB_RTC_TRIG_CLR );
SetSysClock( CLK_SOURCE_HSE_6_4MHz );
LowPower_Sleep( RB_PWR_RAM2K | RB_PWR_RAM16K | RB_PWR_EXTEND );
SetSysClock( CLK_SOURCE_PLL_60MHz );
进入休眠时候的代码如上,只开启按键唤醒,但是唤醒之后发现是RTC中断唤醒的,RTC是使用周期中断。可以肯定是RTC唤醒的,因为只要把RTC中断关闭,在没有按键之类的io中断,系统是不会从休眠中被唤醒。唤醒后打印出R8_SLP_WAKE_CTRL的值为0x10
蔡表胤
2022-8-24 09:47:00
蓝牙的代码,rtc会打开的
