嵌入式技术论坛
王利祥
8年用户 1508经验值
SDK20210609解压后的文件夹根菜单配置失败如何解决
stm32f4下的工程菜单配置正常。
在下载的k7252_camera_release_20210609解压后的文件夹根菜单配置失败。SDK没有做任何更改。
日志:
欢迎使用 RT-Thread env (V1.2.0) 工具
RT - Thread Operating System
2006 - 2019 Copyright by rt-thread team
Online help documents : https://www.rt-thread.org/document/site
Administrator@DESKTOP-OLV8B2G K:\5.beken\bk7252\1.software\bk7221u_release
$ menuconfig
Kconfig:3:warning: ignoring unsupported character '$'
Kconfig:3:warning: environment variable BSP_ROOT undefined
Kconfig:8:warning: ignoring unsupported character '$'
Kconfig:8:warning: environment variable RTT_ROOT undefined
Kconfig:11:warning: ignoring unsupported character ':'
Kconfig:16:warning: ignoring unsupported character '$'
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/system/uffs/Kconfig:25:warning: choice value used outside its choice group
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/system/uffs/Kconfig:28:warning: choice value used outside its choice group
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/system/uffs/Kconfig:31:warning: choice value used outside its choice group
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/system/uffs/Kconfig:34:warning: choice value used outside its choice group
rt-thread/components/drivers/Kconfig:279:warning: config symbol defined without type
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/iot/pahomqtt/Kconfig:56:warning: config symbol defined without type
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/iot/netutils/Kconfig:2:error: recursive dependency detected!
For a resolution refer to Documentation/kbuild/kconfig-language.txt
subsection "Kconfig recursive dependency limitations"
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/iot/netutils/Kconfig:2: symbol PKG_USING_NETUTILS is selected by RTC_SYNC_USING_NTP
rt-thread/components/drivers/Kconfig:95: symbol RTC_SYNC_USING_NTP depends on RT_USING_RTC
rt-thread/components/drivers/Kconfig:87: symbol RT_USING_RTC is selected by PKG_USING_MBEDTLS
K:\100.soft\env_released_1.2.0\env\tools\ConEmu\ConEmu......\packages/packages/security/mbedtls/Kconfig:10: symbol PKG_USING_MBEDTLS depends on RT_USING_SAL
回帖(2)
贾埃罗
2022-8-3 10:12:26
直接改配置吧,有些年久失修了。
王利祥
2022-8-3 10:12:35
我是这个直接菜单配置行
