瑞芯微Rockchip开发者社区
王涛
7年用户 1278经验值
如何让RK3588芯片支持HDMI0接口输出为8K分辨率呢
RK3588 芯片最高支持的输出分辨率可以到8K,由于Android12 SDK要支持多个显示接口,所以默认最高只配置了4K的分辨率支持,下面以RK3588-EVB1的开发板上配置HDMI输出8K输出为例进行说明如何让RK3588支持8K分辨率。 本文配置RK3588-EVB1开发HDMI0接口输出8K分辨率。
提供VOP CLK以支持8K分辨率
提cru ACLK_VOP的频率到800MHz
diff --git a/arch/arm64/boot/dts/rockchip/rk3588s.dtsi b/arch/arm64/boot/dts/rockchip/rk3588s.dtsi
index 2704255b0ca23..1fcb10641dc3e 100644
--- a/arch/arm64/boot/dts/rockchip/rk3588s.dtsi
+++ b/arch/arm64/boot/dts/rockchip/rk3588s.dtsi
        cru: clock-controller@fd7c0000 {
                compatible = "rockchip,rk3588-cru";
                rockchip,grf = <&php_grf>;
                reg = <0x0 0xfd7c0000 0x0 0x5c000>;
                #clock-cells = <1>;
                #reset-cells = <1>;
                assigned-clocks =
                        <&cru PLL_PPLL>, <&cru PLL_AUPLL>,
                        <&cru PLL_NPLL>, <&cru PLL_GPLL>,
                        <&cru ACLK_CENTER_ROOT>,
                        <&cru HCLK_CENTER_ROOT>, <&cru ACLK_CENTER_LOW_ROOT>,
                        <&cru ACLK_TOP_ROOT>, <&cru PCLK_TOP_ROOT>,
                        <&cru ACLK_LOW_TOP_ROOT>, <&cru PCLK_PMU0_ROOT>,
                        <&cru HCLK_PMU_CM0_ROOT>, <&cru ACLK_VOP>,
                        <&cru ACLK_BUS_ROOT>, <&cru CLK_150M_SRC>,
                        <&cru CLK_GPU>;
                assigned-clock-rates =
                        <100000000>, <786432000>,
                        <850000000>, <1188000000>,
                        <702000000>,
                        <400000000>, <500000000>,
                        <800000000>, <100000000>,
                        <400000000>, <100000000>,
-                       <200000000>, <500000000>,
+                       <200000000>, <800000000>,
                        <375000000>, <150000000>,
                        <200000000>;
修改VOP的图层分配
RK3588的有4个vop port分别支持4K+4K+4K+1080P,如果需要支持8K需要把vp0和vp1组合使用,这里只需要把HDMI0分配到vp0上,vp1不分配给其他接口即可,因为SDK中的RK3588-EVB1的dts中HMDI1配置在vp1上面,所以需要把HMDI1改为配置在vp2上面,这样即可空出vp1给HMDI0做8K显示用。
diff --git a/arch/arm64/boot/dts/rockchip/rk3588-evb1-lp4.dtsi b/arch/arm64/boot/dts/rockchip/rk3588-evb1-lp4.dtsi
index 543d78d3f182f..4f4f4b5f01eab 100644
--- a/arch/arm64/boot/dts/rockchip/rk3588-evb1-lp4.dtsi
+++ b/arch/arm64/boot/dts/rockchip/rk3588-evb1-lp4.dtsi
@@ -360,8 +360,8 @@
        status = "okay";
-&hdmi1_in_vp1 {
-       status = "okay";
+&hdmi1_in_vp2 {
+       status = "dokay";
原作者:loitawu
