瑞芯微Rockchip开发者社区
刘燕
8年用户 1435经验值
构建RK3288系统的内核会遇到哪些问题呢
构建RK3288系统的内核会遇到哪些问题呢?怎样去解决?
李淳鑫
2022-3-10 11:12:21
  Platform: ROCKCHIP
  OS: Android 6.0
  Kernel: 3.10.92
  拿到一台新安装的编译用服务器, 版本是:
  Ubuntu 14.04.2 LTS (GNU/Linux 3.16.0-30-generic x86_64)
  开始build会遇到一些缺少package的error,小结如下。
  Build Kernel:
  Error 1:
  build@build--machine:~/rk3288/kernel$ make rk3288-tb_8846.img
  LD vmlinux
  SORTEX vmlinux
  SYSMAP System.map
  OBJCOPY arch/arm/boot/Image
  Kernel: arch/arm/boot/Image is ready
  AS arch/arm/boot/compressed/head.o
  LZO arch/arm/boot/compressed/piggy.lzo
  /bin/sh: 1: lzop: not found
  CC arch/arm/boot/compressed/misc.o
  make[2]: *** [arch/arm/boot/compressed/piggy.lzo] Error 1
  make[2]: *** Waiting for unfinished jobs.。..
  make[2]: *** wait: No child processes. Stop.
  make[1]: *** [arch/arm/boot/compressed/vmlinux] Error 2
  make: *** [zImage] Error 2
  解决办法:
  #sudo apt-get install lzop
  Error 2:
  scripts/kconfig/conf --silentoldconfig Kconfig
  ^C
  CC scripts/mod/devicetable-offsets.s
  GEN scripts/mod/devicetable-offsets.h
  HOSTCC scripts/mod/file2alias.o
  HOSTLD scripts/mod/modpost
  CHK include/generated/uapi/linux/version.h
  CHK include/generated/utsrelease.h
  make[1]: `include/generated/mach-types.h‘ is up to date.
  CALL scripts/checksyscalls.sh
  CHK include/generated/compile.h
  GEN drivers/video/rockchip/screen/lcd.h
  LD arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
  make: *** [kernel.img] Error 127
  #### make failed to build some targets (18 seconds) ####
  解决办法:
  安装64bit机子对32bit程序运行的支持。
  #sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386
  另外,Android 5.1之后用的java环境是 openjdk-7,否则报错。
  解决办法:
  #sudo apt-get install openjdk-7-jdk
  #PATH=/usr/lib/jvm/java-7-openjdk-amd64/bin:$PATH
  Build Android:
  Error1:
  build@build--machine:~/rk3288/kernel$ make -j8
  Notice file: external/jarjar/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//framework/jarjar.jar.txt
  Yacc: aidl 《= frameworks/base/tools/aidl/aidl_language_y.y
  prebuilts/misc/linux-x86/bison/bison -d -o out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp frameworks/base/tools/aidl/aidl_language_y.y
  Notice file: frameworks/base/tools/aidl/NOTICE -- out/host/linux-x86/obj/NOTICE_FILES/src//bin/aidl.txt
  Lex: aidl 《= frameworks/base/tools/aidl/aidl_language_l.l
  make: *** [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_y.cpp] Broken pipe
  make: *** Waiting for unfinished jobs.。..
  flex-2.5.39: fatal internal error, exec of /usr/bin/m4 failed
  frameworks/base/tools/aidl/aidl_language_l.l:55: warning, rule cannot be matched
  make: *** [out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp] Broken pipe
  make: *** Deleting file `out/host/linux-x86/obj/EXECUTABLES/aidl_intermediates/aidl_language_l.cpp’
  Note: Some input files use unchecked or unsafe operations.
  Note: Recompile with -Xlint:unchecked for details.
  Note: Some input files use or override a deprecated API.
  Note: Recompile with -Xlint:deprecation for details.
  解决办法:
  #sudo apt-get install bison
  Error2:
  Copy: out/target/product/rk3288/system/etc/.allBlock
  Copy: out/target/product/rk3288/system/etc/.videoBlock
  Copy xml: out/target/product/rk3288/system/etc/GS8604.xml
  /bin/bash: xmllint: command not found
  make: *** [out/target/product/rk3288/system/etc/GS8604.xml] Error 127
  preparing StaticLib: libc_common [including out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_thread_atexit_impl_intermediates/libc_thread_atexit_impl.a]
  preparing StaticLib: libc_common [including out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_tzcode_intermediates/libc_tzcode.a]
  target StaticLib: libc_common (out/target/product/rk3288/obj/STATIC_LIBRARIES/libc_common_intermediates/libc_common.a)
  #### make failed to build some targets (12:49 (mm:ss)) ####
  解决方法:
  #sudo apt-get install libxml2-utils
