瑞芯微Rockchip开发者社区
ningkui
12年用户 831经验值
擅长:电源/新能源
RK3288***份证模块时摄像头会卡住且无法识别怎么去解决
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
李林
2022-3-10 14:52:18
CPU:RK3288
系统:Android 5.1
主板有两个USB接口,一个接USB摄像头,一个接身份证模块。
插入摄像头可以正常打开,再插入身份证模块时,摄像头就会卡主,而且身份证模块无法识别,内核log如下:
  [ 208.492045] u*** 3-1.3: new full-speed USB device number 7 using u***20_host
[ 208.571251] u*** 3-1.3: device descriptor read/64, error -32
[ 208.758662] u*** 3-1.3: device descriptor read/64, error -32
[ 208.945433] u*** 3-1.3: new full-speed USB device number 8 using u***20_host
[ 209.024159] u*** 3-1.3: device descriptor read/64, error -32
[ 209.211003] u*** 3-1.3: device descriptor read/64, error -32
[ 209.398208] u*** 3-1.3: new full-speed USB device number 9 using u***20_host
[ 209.810731] u*** 3-1.3: device not accepting address 9, error -32
[ 209.890155] u*** 3-1.3: new full-speed USB device number 10 using u***20_host
[ 210.302863] u*** 3-1.3: device not accepting address 10, error -32
[ 210.303805] hub 3-1:1.0: unable to enumerate USB device on port 3
有时可以识别身份证模块,内核log如下:
  [  743.983805] u*** 3-1.4: new full-speed USB device number 10 using u***20_host
[  744.062096] u*** 3-1.4: device descriptor read/64, error -32
[  744.270232] u*** 3-1.4: New USB device found, idVendor=0400, idProduct=c35a
[  744.270433] u*** 3-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
出现这种现象的原因是2组USB使用同一路供电,当身份证模块插入时,瞬间拉低了USB电源,导致USB供电不足。
两种解决办法:
1、两组USB单独供电;
2、在USB电源上接一个较大的电容,防止电压瞬间被拉低。
