说明:本文适用于 RK3288 kernel4.4 SDK 版本。
RK3288 的 HDMI 和 codec 共用一组 i2s 。如果需要 HDMI 和 Codec 同时输出音频,直接使用 SDK 自带的 hdmi_analog_sound 节点配置。如果需要 HDMI 和 codec 可以单独输出,需要将 HDMI 单独注册成一个 PCM 设备。
注:hdmi_analog_sound 和 simple-audio-card 这两种注册方式只能二选一。
HDMI 和 Codec 同时输出
方案一:直接使用 hdmi_analog_sound 默认节点配置( 以 RT5640 为例 )
//RK3288 kernel4.4
hdmi_analog_sound: hdmi-analog-sound {
status = "okay";
compatible = "rockchip,rk3288-hdmi-analog",
"rockchip,rk3368-hdmi-analog";
rockchip,model = "rockchip,rt5640-codec";
rockchip,cpu = <&i2s>;
rockchip,codec = <&rt5640>, <&hdmi>;
rockchip,widgets =
"Microphone", "Microphone Jack",
"Headphone", "Headphone Jack";
rockchip,routing =
"MIC1", "Microphone Jack",
"MIC2", "Microphone Jack",
"Microphone Jack", "micbias1",
"Headphone Jack", "HPOL",
"Headphone Jack", "HPOR";
&i2s {
status = "okay";
&hdmi{
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
#sound-dai-cells = <0>;
compatible = "realtek,rt5640";
reg = <0x1c>;
clocks = <&cru SCLK_I2S0_OUT>;
clock-names = "mclk";
interrupt-parent = <&gpio6>;
interrupts = <7 IRQ_TYPE_EDGE_FALLING>;
pinctrl-names = "default";
pinctrl-0 = <&i2s0_mclk>;
方案二:关闭上层 HDMI 设备插入检测,DTS 用 simple-audio-card 注册 Codec 声卡。
1、上层注释掉 hdmi 设备插入的检测:
diff --git a/services/java/com/android/server/WiredAccessoryManager.java b/services/java/com/android/server/WiredAccessoryManager.java
index c8d3510..2fb231e 100644
--- a/services/java/com/android/server/WiredAccessoryManager.java
+++ b/services/java/com/android/server/WiredAccessoryManager.java
@@ -374,7 +374,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks {
// If the kernel does not have an "hdmi_audio" switch, just fall back on the older
// "hdmi" switch instead.
- uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0);
+/* uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0);
if (uei.checkSwitchExists()) {
retVal.add(uei);
} else {
@@ -385,7 +385,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks {
Slog.w(TAG, "This kernel does not have HDMI audio support");
return retVal;
2、simple-audio-card 注册 Codec 声卡
//RK3288 kernel4.4
rt5640_codec: rt5640-codec{
status = "okay";
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "rockchip,rt5640-codec";
simple-audio-card,mclk-fs = <512>;
simple-audio-card,widgets =
simple-audio-card,routing =
simple-audio-card,dai-link@0 {
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
sound-dai = <&rt5640>;
&i2s {
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
HDMI 和 codec 单独输出
实现 HDMI 和 codec 音频单独输出需要将 hdmi 单独注册成一个 PCM 设备,HDMI 设备插入后上层会切换输出设备为 AUDIO_DEVICE_OUT_HDMI ,然后在 HAL 层打开对应的 PCM 设备即可。
DTS配置如下:
//RK3288 kernel4.4
status = "okay";
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
simple-audio-card,dai-link@1 {
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
sound-dai = <&hdmi>;
&hdmi_analog_sound {
status = "disabled";
&i2s {
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
注册成功后,可以通过 adb 查看注册上的 pcm设备。
rk3228:/ # ls dev/snd
ls dev/snd
. .. controlC0 pcmC0D0c pcmC0D0p pcmC0D1p timer
其中 pcmC0D1p 对应的就是 HDMI pcm 设备,然后在 hal 层调用 pcmC0D1p ,修改如下:
hardware/rockchip/audio/tinyalsa_hal$ git diff .
diff --git a/tinyalsa_hal/audio_hw.c b/tinyalsa_hal/audio_hw.c
index 13dd42e..fd7c664 100755
--- a/tinyalsa_hal/audio_hw.c
+++ b/tinyalsa_hal/audio_hw.c
@@ -615,7 +615,7 @@ static int start_output_stream(struct stream_out *out)
#endif
#endif
- out->pcm[PCM_CARD_HDMI] = pcm_open(PCM_CARD_HDMI, out->pcm_device,
+ out->pcm[PCM_CARD_HDMI] = pcm_open(0, 1,
PCM_OUT | PCM_MONOTONIC, &out->config);
if (out->pcm[PCM_CARD_HDMI] &&
!pcm_is_ready(out->pcm[PCM_CARD_HDMI])) {
注:具体 hdmi 对应的是哪个 pcm 设备需要根据实际情况来定,如果不清楚怎么确认,底层可以先通过 tinyalsa 来确定 hdmi 的 pcm 设备,然后参照上述 hal 层的代码修改成对应的 hdmi pcm 设备 即可。
HDMI 和 Codec 同时输出
//RK3288 kernel4.4
status = "okay";
rockchip,widgets =
rockchip,routing =
&i2s {
status = "okay";
&hdmi{
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
retVal.add(uei);
} else {
return retVal;
//RK3288 kernel4.4
status = "okay";
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
&i2s {
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
HDMI 和 codec 单独输出
DTS配置如下:
//RK3288 kernel4.4
status = "okay";
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
format = "i2s";
cpu {
sound-dai = <&i2s>;
codec {
&i2s {
status = "okay";
&i2c2 {
status = "okay";
rt5640: rt5640@1c {
reg = <0x1c>;
ls dev/snd
#endif
#endif
