主要是/sys/class/leds/standby/brightness和/sys/class/backlight/backlight/brightness这两个节点的选择操作。
--- a/services/core/java/com/android/server/ power/PowerManagerService.java
+++ b/services/core/java/com/android/server/power/PowerManagerService.java
@@ -1257,7 +1257,8 @@ public final class PowerManagerService extends SystemService
Slog.i(TAG , “从打瞌睡中醒来 (uid ” + reasonUid +“)。..”);
休息;
- if(“LVDS”.equals(SystemProperties.get(“sys.hwc.device.primary”, “HDMI-A”)))
+ if(“LVDS”.equals(SystemProperties.get(“sys.hwc. device.primary”, “HDMI-A”)) ||
+ “eDP”.equals(SystemProperties.get(“sys.hwc.device.primary”, “HDMI-A”)))
writeSysfs(“/sys/class/leds/standby/brightness”,“255”);/ /添加为 ctl led
else
writeSysfs(“/sys/class/backlight/backlight/brightness”,“255”);
@@ -1344,7 +1345,8 @@ public final class PowerManagerService extends SystemService
break;
+ if(“LVDS”.equals(SystemProperties.get(“sys.hwc. device.primary”,“HDMI-A”))||
+“eDP”。
writeSysfs(”/sys/class/leds/standby/brightness“,”0“);// addedfor ctl led
else
writeSysfs(”/sys/class/backlight/backlight/brightness“,”0“);
编译更新:
caizd @ubt14c:/work/czd/rk3288_7.1_mid$ mmm frameworks/base/services/
然后替换out/target/product/rk3399_mid/system/framework/services.jar到下面的jar包即可:
rk3288:/#ls -l system/framework/services.jar
-rw-r–r-- 1 root root 3160502 2019-10-23 03:56 system/framework/services.jar
休息;
else
break;
+“eDP”。
else
编译更新:
