瑞芯微Rockchip开发者社区
笑过就走
9年用户 866经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术
如何对RK3399Pro python环境进行配置呢
RK3399Pro python环境有哪些配置呢?如何对RK3399Pro python环境进行配置呢?
王育来
2022-2-11 11:41:07
opencv,tensorflow,pytorch的安装
本人rk3399pro 安装系统为ubuntu18.04系统。
1.配置环境依赖项
sudo apt-get update
sudo apt-get install build-essential cmake git pkg-config
sudo apt-get install libjpeg8-dev libtiff5-dev  libpng-dev
sudo apt-get install libgtk2.0-dev
sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev
sudo apt-get install libatlas-base-dev gfortran  libhdf5-dev libtbb-dev libeigen3-dev
sudo apt-get install gstreamer1.0-tools gstreamer1.0-alsa gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav
sudo apt-get install libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-good1.0-dev libgstreamer-plugins-bad1.0-dev
2.安装pip3,numpy,opencv等
这里opencv采用apt形式安装安装版本为3.2,如需要安装高版本需要源码编译。
sudo apt-get install python3-dev
sudo apt-get install python3-pip
sudo pip3 install --upgrade pip
sudo pip3 config set global.index-url https://pypi.tuna.tsinghua.edu.cn/simple
sudo apt-get install python3-numpy
sudo apt-get install python3-opencv
3.安装tensorflow,keras,pytorch
下面一些whl包,rk3399的github也有下载
sudo pip3 install h5py
sudo pip3 install tensorflow-1.13.1-cp36-none-linux_aarch64.whl
sudo pip3 install onnx-1.4.1-cp36-cp36m-linux_aarch64.whl
sudo pip3 install scipy-1.2.0-cp36-cp36m-linux_aarch64.whl
sudp pip3 install keras==2.1.5
sudo apt-get install python3-matplotlib
sudo pip3 install pillow==6.2.0
sudo apt-get install libopenblas-dev cython3 libatlas-dev m4 libblas-dev cmake
pip3 install pyyaml
sudo pip3 install torch-1.1.0a0+7e73783-cp36-cp36m-linux_aarch64.whl
pip3 install torchvision
#安装rknn python的API
sudo pip3 install rknn_toolkit-1.3.0-cp36-cp36m-linux_aarch64.whl
4.安装图像工具,否则无法显示图片
如何是界面情况下,可能会出现无法显示图片的情况,需要装读图软件。
sudo apt-get install imagemagick
5.添加交换空间
mkdir swap
cd swap
# (1024*4000000=4G)
sudo dd if=/dev/zero of=swapfile bs=1024 count=4000000
sudo mkswap swapfile
chmod 0600 swapfile
sudo swapon swapfile
使用结束释放:
swapoff -a
