单片机学习小组
硬件工程师1
9年用户 1515经验值
擅长:可编程逻辑
请问stm32 USB如何增加端点?
请问STM32 USB如何增加端点?
李俊
2022-1-27 09:22:40
在原有的端点1和端点2基础上增加一个双向端点3.
由于EP3端点缓冲区只有512-32-64*7=32字节大小,所以发送长度不能大于32,否则多余的数据会丢失
1. 修改u***_desc.c
1)将端点数目改为6
  /************** Descriptor of Custom HID interface ****************/
    /* 09 */
    0x09,         /* bLength: Interface Descriptor size */
    USB_INTERFACE_DESCRIPTOR_TYPE,/* bDescriptorType: Interface descriptor type */
    0x00,         /* bInterfaceNumber: Number of Interface */
    0x00,         /* bAlternateSetting: Alternate setting */
    0x06,         /* bNumEndpoints */
    0xDC,         /* bInterfaceClass: Class code = 0DCH */
    0xA0,         /* bInterfaceSubClass : Subclass code = 0A0H */
    0xB0,         /* nInterfaceProtocol : Protocol code = 0B0H */
    0,            /* iInterface: Index of string descriptor */
2)增加端点描述符
    0x07,         /* endpoint descriptor length = 07H */
    USB_ENDPOINT_DESCRIPTOR_TYPE, /* endpoint descriptor type = 05H */
    0x83,         /* endpoint 2 IN */
    0x02,                                              /* bulk transfer = 02H */
    0x40,0x00,    /* endpoint max packet size = 0040H */
    0x0A,         /* the value is invalid when bulk transfer */
    0x03,         /* endpoint 2 OUT */
2. 修改u***_prop.c
1)在void CustomHID_Reset(void)中初始化端点3
  /* Initialize Endpoint 3 */
          SetEPType(ENDP3, EP_BULK);
          SetEPRxAddr(ENDP3, ENDP3_RXADDR);
          SetEPTxAddr(ENDP3, ENDP3_TXADDR);
          SetEPRxCount(ENDP3, EP_SIZE);
          SetEPRxStatus(ENDP3, EP_RX_VALID);
          SetEPTxStatus(ENDP3, EP_TX_NAK);
3. 修改u***_conf.h
1)将端点书改为4
#define EP_NUM     (4)
2)修改端点缓冲地址
/* buffer table base address */
#define BTABLE_ADDRESS      (0x00)
/* EP0  */
/* rx/tx buffer base address */
#define ENDP0_RXADDR        (0x20)  //4*8=0x20,参照有道笔记“STM32 USB端点修改”
#define ENDP0_TXADDR        (0x60)
/* EP1  */
/* tx buffer base address */
//地址为32位对其,位4的倍数,不能超过 bMaxPacketSize
//EP1
#define ENDP1_RXADDR        (0xa0)  //每个缓冲区大小64
#define ENDP1_TXADDR        (0xa0+64)
EP2
#define ENDP2_RXADDR        (0xa0+64+64)
#define ENDP2_TXADDR        (0xa0+64+64+64)
EP3
#define ENDP3_RXADDR        (0xa0+64+64+64+64)
#define ENDP3_TXADDR        (0xa0+64+64+64+64+64)
3)注释回调函数
//#define  EP3_IN_Callback   NOP_Process
//#define  EP3_OUT_Callback   NOP_Process
4. 修改u***_endp.c
1)在void EP3_OUT_Callback(void)中实现u***接收数据处理
2)void EP3_IN_Callback(void)可不用实现
5. 修改u***io.c
1)封装上层接收与发送接口
