瑞芯微Rockchip开发者社区
纯纯纯牛奶
12年用户 522经验值
imx8mm开发板在编译中LT8912.lo报错是为什么?
  • [td]  CC      drivers/gpu/drm/i915/i915_perf.o
      CC      drivers/gpu/drm/i915/i915_oa_hsw.o
      CC      drivers/gpu/drm/i915/i915_oa_bdw.o
      CC      drivers/gpu/drm/i915/i915_oa_chv.o
      CC      drivers/gpu/drm/i915/i915_oa_sklgt2.o
      CC      drivers/gpu/drm/i915/i915_oa_sklgt3.o
      CC      drivers/gpu/drm/i915/i915_oa_sklgt4.o
      CC      drivers/gpu/drm/i915/i915_oa_bxt.o
      CC      drivers/gpu/drm/i915/i915_oa_kblgt2.o
      CC      drivers/gpu/drm/i915/i915_oa_kblgt3.o
      CC      drivers/gpu/drm/i915/i915_oa_glk.o
      CC      drivers/gpu/drm/i915/intel_lpe_audio.o
      AR      drivers/gpu/drm/i915/i915.o
      AR      drivers/gpu/drm/i915/built-in.o
      AR      drivers/gpu/drm/built-in.o
      AR      drivers/gpu/built-in.o
      AR      drivers/built-in.o
      GEN     .version
    make[2]: Entering directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
    make[2]: warning: jobserver unavailable: using -j1.  Add '+' to parent make rule.
      CHK     include/generated/compile.h
      UPD     include/generated/compile.h
      CC      init/version.o
      AR      init/built-in.o
    make[2]: Leaving directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
      AR      built-in.o
      LD      vmlinux.o
    ld: drivers/gpu/drm/bridge/lt8912.lo: Relocations in generic ELF (EM: 183)
    drivers/gpu/drm/bridge/lt8912.lo: error adding symbols: File in wrong format
    Makefile:1020: recipe for target 'vmlinux' failed
    make[1]: *** [vmlinux] Error 1
    make[1]: Leaving directory '/home/yq/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel'
    Makefile:11: recipe for target 'linux' failed
    make: *** [linux] Error 2
    [/td]
黄晔华
2022-1-13 10:38:57
您都执行了哪些指令啊?有修改过源码吗?
