瑞芯微Rockchip开发者社区
一瞅一个准
12年用户 837经验值
SDK下使用make u-boot编译NXP官方下载的u-boot编译不成功怎么办?
SDK下使用make u-boot编译NXP官方下载的u-boot编译不成功。
  •   MKIMAGE u-boot.img
  •   MKIMAGE u-boot-dtb.img
  •   CAT     u-boot-dtb.bin
  •   COPY    u-boot.bin
  •   LD      u-boot.elf
  •   CC      spl/common/spl/spl.o
  •   CC      spl/arch/arm/cpu/armv8/fwcall.o
  •   CC      spl/lib/display_options.o
  •   LD      spl/arch/arm/cpu/armv8/built-in.o
  •   LD      spl/common/spl/built-in.o
  •   LD      spl/lib/built-in.o
  •   LD      spl/u-boot-spl
  •   OBJCOPY spl/u-boot-spl-nodtb.bin
  •   COPY    spl/u-boot-spl.bin
  •   MKIMAGE SPL
  •   CFGCHK  u-boot.cfg
  • make[1]: Leaving directory '/home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/OK8MM-linux-uboot/uboot-imx'
  • install /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/OK8MM-linux-uboot/uboot-imx/u-boot-nodtb.bin /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/images/u-boot
  • install /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/OK8MM-linux-uboot/uboot-imx/spl/u-boot-spl.bin /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/images/u-boot
  • make -C /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/tools/imx-boot-tools clean
  • make[1]: Entering directory '/home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/tools/imx-boot-tools'
  • make[1]: Leaving directory '/home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/tools/imx-boot-tools'
  • make -C /home/ubuntu/workspace/imx8mm/sdk/OK8MM-linux-sdk/tools/imx-boot-tools flash_ddr4_evk_no_hdmi SOC=iMX8MM
  • make[1]: *** No rule to make target 'fsl-imx8mm-evk.dtb', needed by 'u-boot.itb'.  Stop.
  • Makefile:44: recipe for target 'u-boot' failed
  • make: *** [u-boot] Error 2
这个问题怎么解决呢?
刘宇
2021-12-31 10:10:21
主要是没把uboot中的fsl-imx8mm-evk.dtb放到imx-boot-tools下,
创建软链接解决。
  • ubuntu@ubuntu:~/workspace/imx8mm/sdk/OK8MM-linux-sdk/tools/imx-boot-tools$ ln -s ../../OK8MM-linux-uboot/uboot-imx/arch/arm/dts/fsl-imx8mm-evk.dtb fsl-imx8mm-evk.dtb
