HiHope开发者社区
h1654155754.5980
13年用户 59经验值
擅长:嵌入式技术
wifi_connect_demo.c无法编译?
neptune开发板,neptunt-hARMony-os1.1-iot-master源码,测试wifi_connect_demo.c时,无法编译。但是测试wifi_scan_demo.c这个样本时,编译通过,并且能够下载到开发板中,能够得到scan后的wifi地址,按照说明更改BUILD.gn后,添加wifi_cnnect_demo.c后,编译无法通过,提示报警“./../applications/sample/wifi-iot/app/wifi/wifi_connect_demo.c:39:28: fatal error: lwip/api_shell.h: No such file or directory”,这个问题如何解决?
下面是build.log 信息:
WARNING at the command-line "--args":1:339: Build argument has no effect.
ohos_build_compiler_specified="gcc" product_path="/home/wxd/Projects/neptune-harmony-os1.1-iot-master/vendor/winnermicro/neptune" device_path="/home/wxd/Projects/neptune-harmony-os1.1-iot-master/device/winnermicro/neptune/sdk_liteos" ohos_kernel_type="liteos_m" ohos_build_type="debug" ohos_build_time="1640210744417" ohos_build_datetime="2021-12-23 14:05:44" ohos_full_compile=true
The variable "ohos_build_datetime" was set as a build argument
but never appeared in a declare_args() block in any buildfile.
To view all possible args, run "gn args --list "
The build continued as if that argument was unspecified.
Done. Made 78 targets from 63 files in 195ms
ninja: Entering directory `/home/wxd/Projects/neptune-harmony-os1.1-iot-master/out/neptune/wifiiot_neptune'
[1/394] gcc cross compiler obj/applications/sample/wifi-iot/app/demolink/libexample_demolink.helloworld.o
../../../applications/sample/wifi-iot/app/demolink/helloworld.c: In function ‘DemoSdkMain’:
../../../applications/sample/wifi-iot/app/demolink/helloworld.c:22:5: warning: implicit declaration of function ‘printf’ [-Wimplicit-function-declaration]
     printf("start test task ........");
[2/394] gcc cross compiler obj/applications/sample/wifi-iot/app/iothardware/libgpio_example.gpio_example.o
[3/394] AR libs/libexample_demolink.a
[4/394] AR libs/libgpio_example.a
[5/394] gcc cross compiler obj/applications/sample/wifi-iot/app/wifi/libwifi_demo.wifi_connect_demo.o
FAILED: obj/applications/sample/wifi-iot/app/wifi/libwifi_demo.wifi_connect_demo.o
csky-abiv2-elf-gcc -D_XOPEN_SOURCE=700 -DOHOS_DEBUG -D__LITEOS__ -D__LITEOS_M__ -I../../../utils/native/lite/include -I../../../kernel/liteos_m/components/cmsis/2.0 -I../../../base/iot_hardware/interfaces/kits/wifiiot_lite -I../../../foundation/communication/interfaces/kits/wifi_lite/wifiservice -I../../../vendor/hisi/hi3861/hi3861/third_party/lwip_sack/include -I../../../foundation/communication/wifi_lite/interfaces/wifiservice -I../../../kernel/liteos_m/components/bounds_checking_function/include -I../../../kernel/liteos_m/kal -I../../../kernel/liteos_m/kal/cmsis -I../../../kernel/liteos_m/kernel/include -I../../../kernel/liteos_m/targets/csky_ck804ef_w800_gcc -I../../../kernel/liteos_m/utils -I../../../utils/native/lite/include -I../../../third_party/mbedtls/include -I../../../kernel/liteos_m/kal/posix/include -I../../../device/winnermicro/neptune/sdk_liteos/include -I../../../device/winnermicro/neptune/sdk_liteos/include/los -I../../../device/winnermicro/neptune/sdk_liteos/include/wifi -I../../../device/winnermicro/neptune/sdk_liteos/include/platform -I../../../device/winnermicro/neptune/sdk_liteos/include/arch/xt804 -I../../../device/winnermicro/neptune/sdk_liteos/include/arch/xt804/csi_core -I../../../device/winnermicro/neptune/sdk_liteos/include/net -I../../../device/winnermicro/neptune/sdk_liteos/include/driver -I../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include -I../../../device/winnermicro/neptune/sdk_liteos/include/app -I../../../device/winnermicro/neptune/sdk_liteos/include/os -Os -falign-functions=2 -std=c99 -Wextra -Wall -mhard-float -mcpu=ck804ef -Os -fno-schedule-insns -Wpointer-arith -fdata-sections -mcpu=ck804ef -nostdlib -fno-common -fno-builtin -fno-strict-aliasing -Wall -fsigned-char -std=c99 -c ../../../applications/sample/wifi-iot/app/wifi/wifi_connect_demo.c -o obj/applications/sample/wifi-iot/app/wifi/libwifi_demo.wifi_connect_demo.o
In file included from ../../../device/winnermicro/neptune/sdk_liteos/include/os/wm_osal.h:17:0,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/arch/sys_arch.h:5,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/lwip/sys.h:95,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/lwip/netifapi.h:39,
                 from ../../../applications/sample/wifi-iot/app/wifi/wifi_connect_demo.c:38:
../../../device/winnermicro/neptune/sdk_liteos/include/arch/xt804/csi_core/core_804.h: In function ‘csi_coret_config’:
../../../device/winnermicro/neptune/sdk_liteos/include/arch/xt804/csi_core/core_804.h:961:67: warning: unused parameter ‘IRQn’ [-Wunused-parameter]
__STATIC_INLINE uint32_t csi_coret_config(uint32_t ticks, int32_t IRQn)
In file included from ../../../device/winnermicro/neptune/sdk_liteos/include/net/wm_sockets.h:13:0,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/lwip/ip_addr.h:45,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/lwip/netif.h:46,
                 from ../../../device/winnermicro/neptune/sdk_liteos/src/network/lwip2.0.3/include/lwip/netifapi.h:40,
../../../device/winnermicro/neptune/sdk_liteos/include/net/wm_sockets2.0.3.h: At top level:
../../../device/winnermicro/neptune/sdk_liteos/include/net/wm_sockets2.0.3.h:471:20: warning: ‘struct timeval’ declared inside parameter list will not be visible outside of this definition or declaration
             struct timeval *timeout);
../../../applications/sample/wifi-iot/app/wifi/wifi_connect_demo.c:39:28: fatal error: lwip/api_shell.h: No such file or directory
#include "lwip/api_shell.h"
compilation terminated.
[6/394] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_event.o
[7/394] gcc cross compiler obj/base/hiviewdfx/hilog_lite/frameworks/mini/libhilog_lite.hiview_log.o
[8/394] gcc cross compiler obj/base/hiviewdfx/hiview_lite/libhiview_lite.hiview_cache.o
[9/394] gcc cross compiler obj/base/hiviewdfx/hilog_lite/command/libhilog_lite_command.hilog_lite_command.o
[10/394] gcc cross compiler obj/base/hiviewdfx/hievent_lite/frameworks/libhievent_lite.hiview_output_event.o
ninja: build stopped: subcommand failed.
魏义和
2022-1-2 15:22:44
wifi_cnnect_demo.c,这个你怎么些的,截图看看呢。
