卞轮辉
7年用户 1029经验值
基于STM32F103的FreeRTOS移植其代码该如何去实现呢
怎样去移植基于STM32F103的FreeRTOS系统呢?
基于STM32F103的FreeRTOS移植其代码该如何去实现呢?
孙缅禧
2021-12-14 09:17:22
STM32F103 FreeRTOS记录
一、移植(测试RTOSled)
1.添加freertos9.相关文件。
2.在头文件添加下面代码并注释掉stm32f10x_it.c文件里的相关函数
#define vPortSVCHandler SVC_Handler
#define xPortPendSVHandler PendSV_Handler
#define xPortSysTickHandler SysTick_Handler
3.设置:  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
4.代码如下:
  * @file    Project/STM32F10x_StdPeriph_Template/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include
#include
#include "FreeRTOS.h"
#include "task.h"
#include "delay.h"
#include "sysclk.h"
#include "usart.h"
#include "adc.h"
unsigned int spa=0,mill=0,uart_num=0,dma_recv_num=0;
char RX_Buffer[50]={" "};
char RT_Buffer[50]={0};
char DM_RX_BUF[5]={0};
TaskHandle_t  xLedTask1 = NULL,xLedTask2 = NULL,xCNTask=NULL,xGetStackTask=NULL;
unsigned char RX_Buffer_Temp=' ',rec_flag=0,dma_receive_flag=0;
unsigned char uart1_tc5_flag=0;
unsigned int ssp=0,ds_count=0,adc_ds_count=0,OneMill2=0,OneMill1=0;
float ADC_ConvertedValue=0;
void MyGPIO_Init()
        GPIO_InitTypeDef    GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
void Process_Led1(void *pvParameters)
        while(1)
                GPIOC->ODR ^= GPIO_Pin_0;
                vTaskDelay(100);
                OneMill1++;
void Process_Led2(void *pvParameters)
        while(1)
                GPIOC->ODR ^= GPIO_Pin_1;
                vTaskDelay(100);
                OneMill2++;
void Process_Count(void *pvParameters)
        while(1)
                vTaskDelay(100);
                printf("The rtos1 is %d,rtos2 is %d",OneMill1,OneMill2);
RCC_ClocksTypeDef RCC_Clocks;
int main(void)
        MyGPIO_Init();
        SystemClk_Init();
        Uart1_Init();
        Usart1_DMA_init();
        ADC1_CH4_Init();
        RCC_GetClocksFreq(&RCC_Clocks);
        Init_NVIC();
        xTaskCreate(Process_Led1, "LED_TEST1", 60, NULL, 2, &xLedTask1);
        xTaskCreate(Process_Led2, "LED_TEST2", 60, NULL, 2, &xLedTask2);
        xTaskCreate(Process_Count, "PRO_CN", 60, NULL, 2, &xCNTask);
        //xTaskCreate(Process_GetStack, "GET_STACK", 70, NULL, 2, &xGetStackTask);
        vTaskStartScheduler();
void ADC1_2_IRQHandler(void)
        if(ADC_GetITStatus(ADC1,ADC_IT_EOC)==SET)
                //ADC_ClearITPendingBit(ADC1,ADC_IT_EOC);
                if(adc_ds_count<65500)adc_ds_count++;
void USART1_IRQHandler(void)
  unsigned char uart_info=0;
        uart_info=uart_info;
  if(USART_GetITStatus(USART1,USART_IT_IDLE) == SET)
                uart_info = USART1->SR;
    uart_info = USART1->DR;
                DMA_Cmd(DMA1_Channel5,DISABLE);
                dma_recv_num = 200 -  DMA_GetCurrDataCounter(DMA1_Channel5);
                DMA1_Channel5->CNDTR=200;
                DMA_Cmd(DMA1_Channel5,ENABLE);
                dma_receive_flag = 1;
void DMA1_Channel5_IRQHandler(void)
    if(DMA_GetITStatus(DMA1_IT_TC5) == SET)
                        DMA_ClearFlag(DMA1_IT_TC5);
void DMA1_Channel4_IRQHandler(void)
    if(DMA_GetITStatus(DMA1_IT_TC4) == SET)
                        DMA_ClearFlag(DMA1_IT_TC4);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %drn", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
