王晾其
8年用户 1070经验值
怎样将STM32F030的时钟源由HSE修改为HSI时钟呢
怎样将STM32F030的时钟源由HSE修改为HSI时钟呢?有哪些具体操作?
马秀英
2021-10-22 10:47:42
  修改SetSysClock()函数,将时钟源由默认的HSE改为内部HSI时钟
  system_stm32f0xx.c
  static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSIStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
  /* Enable HSI */
  RCC-》CR |= ((uint32_t)RCC_CR_HSION);//((uint32_t)RCC_CR_HSEON)
  /* Wait till HSI is ready and if Time out is reached exit */
  do
  HSIStatus = RCC-》CR & RCC_CR_HSIRDY;//RCC-》CR & RCC_CR_HSERDY;
  StartUpCounter++;
  } while((HSIStatus == 0) && (StartUpCounter != HSI_STARTUP_TIMEOUT));
  if ((RCC-》CR & RCC_CR_HSIRDY) != RESET)//((RCC-》CR & RCC_CR_HSERDY) != RESET
  HSIStatus = (uint32_t)0x01;
  else
  HSIStatus = (uint32_t)0x00;
  if (HSIStatus == (uint32_t)0x01)
  /* Enable Prefetch Buffer and set Flash Latency */
  FLASH-》ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
  /* HCLK = SYSCLK */
  RCC-》CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  /* PCLK = HCLK */
  RCC-》CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
  /* PLL configuration = HSE * 6 = 48 MHz */
  /* PLL configuration = HSI/2 * 12 = 48 MHz */
  RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL));
  RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_DIV2| RCC_CFGR_PLLMULL12);
  // RCC-》CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6)
  /* Enable PLL */
  RCC-》CR |= RCC_CR_PLLON;
  /* Wait till PLL is ready */
  while((RCC-》CR & RCC_CR_PLLRDY) == 0)
  /* Select PLL as system clock source */
  RCC-》CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  RCC-》CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  /* Wait till PLL is used as system clock source */
  while ((RCC-》CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
  else
  { /* If HSI fails to start-up, the application will have wrong clock
  configuration. User can add here some code to deal with this error */
