数码管动态显示
四位共阳极数码管,段码给0显示
main.c
#include “sys.h”
#include “delay.h”
//#include “led.h”
#include “num.h”
int main(void)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //系统时钟设置PLL作为系统时钟
delay_init(); //初始化延时函数
NUM_MOVE(); //数码管动态函数
num.c
#include “num.h”
#include “delay.h”
//动态数码管段码
unsigned char seg[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
//数码管初始化
void NUM_Init(void){
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能GPIO端口时钟,数码管显示GPIO使能配置
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //位选使能
//段码设置
GPIO_InitStructure.GPIO_Pin = NUM_STATIC_GPIO; //数码管段选显示GPIO引脚配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz; //最高输出速率50MHz
GPIO_Init(GPIOD, &GPIO_InitStructure); //IO口初始化
//位选设置
GPIO_InitStructure.GPIO_Pin = NUM_STATIC_BIT; //数码管位选显示GPIO引脚配置
GPIO_Init(GPIOC, &GPIO_InitStructure); //IO口初始化
GPIO_ResetBits(GPIOC, NUM_STATIC_BIT); //给数码管位码置0
//数码管动态函数
void NUM_MOVE(void){
uint16_t i;
NUM_Init();
while(1)
for(i=0;i《16;i++)
GPIO_Write(GPIOD,seg[i]); //段码输出
delay_ms(3000);
num.h
#include “sys.h”
//段码引脚
#define NUM_STATIC_GPIO GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7
#define NUM_STATIC_BIT GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3
//数码管动态函数
void NUM_MOVE(void);
数码管动态显示
四位共阳极数码管,段码给0显示
main.c
#include “sys.h”
#include “delay.h”
//#include “led.h”
#include “num.h”
int main(void)
num.c
#include “num.h”
#include “delay.h”
//动态数码管段码
//数码管初始化
//段码设置
//位选设置
//数码管动态函数
uint16_t i;
NUM_Init();
while(1)
for(i=0;i《16;i++)
delay_ms(3000);
num.h
#include “sys.h”
//段码引脚
//数码管动态函数
