打开arduino IDE 软件,菜单栏文件--》示例--》ArduinoISP,这就是官方的isp下载器代码。直接打开
这里介绍下icsp口的定义
味噌(50个)5V
SCK(52名)MOSI(51个)
RST地线
洋洋装着这个电容是10uf的,接地
当然也能这样接,这样要下载的板子就不用再接电源了
这里下,Arduino UNO和Mega2560的口定义是不一样的,需要按修改。程直接操作是不能
改变的地方是这样的代码
#define USE_OLD_STYLE_WIRING
#ifdef USE_OLD_STYLE_WIRING
#define PIN_MOSI 11
#define PIN_MISO 12
#define PIN_SCK 13
#endif
改成这个改成这个因为mega2560的原因就是这样定义,具体可查看手册
#define USE_OLD_STYLE_WIRING //此处别忘记取消注释
#define PIN_MOSI 51 //mega2560的MOSI 11
#define PIN_MISO 50 //mega2560的MISO 12
#define PIN_SCK 52 //mega2560的SCK 13
#endif
下面附上修改的代码
// ArduinoISP
//reset引脚接10uf电容 到 gnd ,就是10号引脚
// Copyright (c) 2008-2011 Randall Bohn
// If you require a license, see
// [url=http://www.opensource.org/licenses/bsd-license.php]http://www.opensource.org/licenses/bsd-license.php[/url]
// This sketch turns the Arduino into a AVRISP
// using the following arduino pins:
// Pin 10 is used to reset the target microcontroller.
// By default, the hardware SPI pins MISO, MOSI and SCK pins are used
// to communicate with the target. On all Arduinos, these pins can be found
// on the ICSP/SPI header:
// MISO °。 。 5V (!) Avoid this pin on Due, Zero.。。
// SCK 。 。 MOSI
// 。 。 GND
// On some Arduinos (Uno,。。.), pins MOSI, MISO and SCK are the same pins
// as digital pin 11, 12 and 13, respectively. That is why many tutorials
// instruct you to hook up the target to these pins. If you find this wiring
// more practical, have a define USE_OLD_STYLE_WIRING. This will work even
// even when not using an Uno. (On an Uno this is not needed)。
// Alternatively you can use any other digital pin by configuring software (‘BitBanged’)
// SPI and having appropriate defines for PIN_MOSI, PIN_MISO and PIN_SCK.
// IMPORTANT: When using an Arduino that is not 5V tolerant (Due, Zero, 。。.)
// as the programmer, make sure to not expose any of the programmer‘s pins to 5V.
// A simple way to accomplish this is to power the complete system (programmer
// and target) at 3V3.
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat - shows the programmer is running
// 8: Error - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
#include “Arduino.h”
#undef SERIAL
#define PROG_FLICKER true
// Configure SPI clock (in Hz)。
// E.g. for an attiny @128 kHz: the datasheet states that both the high
// and low spi clock pulse must be 》 2 cpu cycles, so take 3 cycles i.e.
// divide target f_cpu by 6:
// #define SPI_CLOCK (128000/6)
// A clock slow enough for an attiny85 @ 1MHz, is a reasonable default:
#define SPI_CLOCK (1000000/6)
// Select hardware or software SPI, depending on SPI clock.
// Currently only for AVR, for other archs (Due, Zero,。。.),
// hardware SPI is probably too fast anyway.
#if defined(ARDUINO_ARCH_AVR)
#if SPI_CLOCK 》 (F_CPU / 128)
#define USE_HARDWARE_SPI
#endif
#endif
// Configure which pins to use:
// The standard pin configuration.
#ifndef ARDUINO_HOODLOADER2
#define RESET 10 // Use pin 10 to reset the target rather than SS
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
// Uncomment following line to use the old Uno style wiring
// (using pin 11, 12 and 13 instead of the SPI header) on Leonardo, Due.。。
#endif
// HOODLOADER2 means running sketches on the atmega16u2
// serial converter chips on Uno or Mega boards.
// We must use pins that are broken out:
#else
#define RESET 10
#define LED_HB 7
#define LED_ERR 6
#define LED_PMODE 5
#endif
By default, use hardware SPI pins:
//#ifndef PIN_MOSI
//#define PIN_MOSI MOSI
//#endif
//#ifndef PIN_MISO
//#define PIN_MISO MISO
//#endif
//#ifndef PIN_SCK
//#define PIN_SCK SCK
//#endif
Force bitbanged SPI if not using the hardware SPI pins:
//#if (PIN_MISO != MISO) || (PIN_MOSI != MOSI) || (PIN_SCK != SCK)
//#undef USE_HARDWARE_SPI
//#endif
// Configure the serial port to use.
// Prefer the USB virtual serial port (aka. native USB port), if the Arduino has one:
// - it does not autoreset (except for the magic baud rate of 1200)。
// - it is more reliable because of USB handshaking.
// Leonardo and similar have an USB virtual serial port: ’Serial‘。
// Due and Zero have an USB virtual serial port: ’SerialUSB‘。
// On the Due and Zero, ’Serial‘ can be used too, provided you disable autoreset.
// To use ’Serial‘: #define SERIAL Serial
#ifdef SERIAL_PORT_USBVIRTUAL
#define SERIAL SERIAL_PORT_USBVIRTUAL
#else
#endif
// Configure the baud rate:
#define BAUDRATE 19200
// #define BAUDRATE 115200
// #define BAUDRATE 1000000
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20 //ok it is a space.。。
void pulse(int pin, int times);
#ifdef USE_HARDWARE_SPI
#include “SPI.h”
#else
#define SPI_MODE0 0x00
class SPISettings {
public:
// clock is in Hz
SPISettings(uint32_t clock, uint8_t bitOrder, uint8_t dataMode) : clock(clock){
(void) bitOrder;
(void) dataMode;
private:
uint32_t clock;
friend class BitBangedSPI;
class BitBangedSPI {
public:
void begin() {
digitalWrite(PIN_SCK, LOW);
digitalWrite(PIN_MOSI, LOW);
pinMode(PIN_SCK, OUTPUT);
pinMode(PIN_MOSI, OUTPUT);
pinMode(PIN_MISO, INPUT);
void beginTransaction(SPISettings settings) {
pulseWidth = (500000 + settings.clock - 1) / settings.clock;
if (pulseWidth == 0)
pulseWidth = 1;
void end() {}
uint8_t transfer (uint8_t b) {
for (unsigned int i = 0; i 《 8; ++i) {
digitalWrite(PIN_MOSI, (b & 0x80) ? HIGH : LOW);
digitalWrite(PIN_SCK, HIGH);
delayMicroseconds(pulseWidth);
b = (b 《《 1) | digitalRead(PIN_MISO);
digitalWrite(PIN_SCK, LOW); // slow pulse
return b;
private:
unsigned long pulseWidth; // in microseconds
static BitBangedSPI SPI;
#endif
void setup() {
SERIAL.begin(BAUDRATE);
pinMode(LED_PMODE, OUTPUT);
pulse(LED_PMODE, 2);
pinMode(LED_ERR, OUTPUT);
pulse(LED_ERR, 2);
pinMode(LED_HB, OUTPUT);
pulse(LED_HB, 2);
int error = 0;
int pmode = 0;
// address for reading and writing, set by ’U‘ command
unsigned int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
uint8_t devicecode;
uint8_t revision;
uint8_t progtype;
uint8_t parmode;
uint8_t polling;
uint8_t selftimed;
uint8_t lockbytes;
uint8_t fusebytes;
uint8_t flashpoll;
uint16_t eeprompoll;
uint16_t pagesize;
uint16_t eepromsize;
uint32_t flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval = 128;
int8_t hbdelta = 8;
void heartbeat() {
static unsigned long last_time = 0;
unsigned long now = millis();
if ((now - last_time) 《 40)
return;
last_time = now;
if (hbval 》 192) hbdelta = -hbdelta;
if (hbval 《 32) hbdelta = -hbdelta;
hbval += hbdelta;
analogWrite(LED_HB, hbval);
static bool rst_active_high;
void reset_target(bool reset) {
digitalWrite(RESET, ((reset && rst_active_high) || (!reset && !rst_active_high)) ? HIGH : LOW);
void loop(void) {
// is pmode active?
if (pmode) {
digitalWrite(LED_PMODE, HIGH);
} else {
digitalWrite(LED_PMODE, LOW);
// is there an error?
if (error) {
digitalWrite(LED_ERR, HIGH);
} else {
digitalWrite(LED_ERR, LOW);
// light the heartbeat LED
heartbeat();
if (SERIAL.available()) {
avrisp();
uint8_t getch() {
while (!SERIAL.available());
return SERIAL.read();
void fill(int n) {
for (int x = 0; x 《 n; x++) {
buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
do {
digitalWrite(pin, HIGH);
delay(PTIME);
digitalWrite(pin, LOW);
delay(PTIME);
} while (times--);
void prog_lamp(int state) {
if (PROG_FLICKER) {
digitalWrite(LED_PMODE, state);
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
SPI.transfer(a);
SPI.transfer(b);
SPI.transfer(c);
return SPI.transfer(d);
void empty_reply() {
if (CRC_EOP == getch()) {
SERIAL.print((char)STK_INSYNC);
SERIAL.print((char)STK_OK);
} else {
error++;
SERIAL.print((char)STK_NOSYNC);
void breply(uint8_t b) {
SERIAL.print((char)b);
} else {
error++;
void get_version(uint8_t c) {
switch (c) {
case 0x80:
breply(HWVER);
break;
case 0x81:
breply(SWMAJ);
break;
case 0x82:
breply(SWMIN);
break;
case 0x93:
breply(’S‘); // serial programmer
break;
default:
breply(0);
void set_parameters() {
// call this after reading paramter packet into buff[]
param.devicecode = buff[0];
param.revision = buff[1];
param.progtype = buff[2];
param.parmode = buff[3];
param.polling = buff[4];
param.selftimed = buff[5];
param.lockbytes = buff[6];
param.fusebytes = buff[7];
param.flashpoll = buff[8];
// ignore buff[9] (= buff[8])
// following are 16 bits (big endian)
param.eeprompoll = beget16(&buff[10]);
param.pagesize = beget16(&buff[12]);
param.eepromsize = beget16(&buff[14]);
// 32 bits flashsize (big endian)
param.flashsize = buff[16] * 0x01000000
+ buff[17] * 0x00010000
+ buff[18] * 0x00000100
+ buff[19];
// avr devices have active low reset, at89sx are active high
rst_active_high = (param.devicecode 》= 0xe0);
void start_pmode() {
// Reset target before driving PIN_SCK or PIN_MOSI
// SPI.begin() will configure SS as output,
// so SPI master mode is selected.
// We have defined RESET as pin 10,
// which for many arduino’s is not the SS pin.
// So we have to configure RESET as output here,
// (reset_target() first sets the correct level)
reset_target(true);
pinMode(RESET, OUTPUT);
SPI.begin();
SPI.beginTransaction(SPISettings(SPI_CLOCK, MSBFIRST, SPI_MODE0));
// See avr datasheets, chapter “SERIAL_PRG Programming Algorithm”:
// Pulse RESET after PIN_SCK is low:
delay(20); // discharge PIN_SCK, value arbitrally chosen
reset_target(false);
// Pulse must be minimum 2 target CPU clock cycles
// so 100 usec is ok for CPU speeds above 20KHz
delayMicroseconds(100);
reset_target(true);
// Send the enable programming command:
delay(50); // datasheet: must be 》 20 msec
spi_transaction(0xAC, 0x53, 0x00, 0x00);
pmode = 1;
void end_pmode() {
SPI.end();
// We‘re about to take the target out of reset
// so configure SPI pins as input
pinMode(PIN_MOSI, INPUT);
pinMode(PIN_SCK, INPUT);
pinMode(RESET, INPUT);
pmode = 0;
void universal() {
uint8_t ch;
fill(4);
ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
breply(ch);
void flash(uint8_t hilo, unsigned int addr, uint8_t data) {
spi_transaction(0x40 + 8 * hilo,
addr 》》 8 & 0xFF,
addr & 0xFF,
data);
void commit(unsigned int addr) {
if (PROG_FLICKER) {
prog_lamp(LOW);
spi_transaction(0x4C, (addr 》》 8) & 0xFF, addr & 0xFF, 0);
if (PROG_FLICKER) {
delay(PTIME);
prog_lamp(HIGH);
unsigned int current_page() {
if (param.pagesize == 32) {
return here & 0xFFFFFFF0;
if (param.pagesize == 64) {
return here & 0xFFFFFFE0;
if (param.pagesize == 128) {
return here & 0xFFFFFFC0;
if (param.pagesize == 256) {
return here & 0xFFFFFF80;
return here;
void write_flash(int length) {
fill(length);
SERIAL.print((char) STK_INSYNC);
SERIAL.print((char) write_flash_pages(length));
} else {
error++;
SERIAL.print((char) STK_NOSYNC);
uint8_t write_flash_pages(int length) {
int x = 0;
unsigned int page = current_page();
while (x 《 length) {
if (page != current_page()) {
commit(page);
flash(LOW, here, buff[x++]);
flash(HIGH, here, buff[x++]);
here++;
commit(page);
return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(unsigned int length) {
// here is a word address, get the byte address
unsigned int start = here * 2;
unsigned int remaining = length;
if (length 》 param.eepromsize) {
error++;
return STK_FAILED;
while (remaining 》 EECHUNK) {
write_eeprom_chunk(start, EECHUNK);
start += EECHUNK;
remaining -= EECHUNK;
write_eeprom_chunk(start, remaining);
return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(unsigned int start, unsigned int length) {
// this writes byte-by-byte,
// page writing may be faster (4 bytes at a time)
fill(length);
prog_lamp(LOW);
for (unsigned int x = 0; x 《 length; x++) {
unsigned int addr = start + x;
spi_transaction(0xC0, (addr 》》 8) & 0xFF, addr & 0xFF, buff[x]);
delay(45);
prog_lamp(HIGH);
return STK_OK;
void program_page() {
char result = (char) STK_FAILED;
unsigned int length = 256 * getch();
length += getch();
char memtype = getch();
// flash memory @here, (length) bytes
if (memtype == ’F‘) {
write_flash(length);
return;
if (memtype == ’E‘) {
result = (char)write_eeprom(length);
SERIAL.print(result);
} else {
error++;
return;
SERIAL.print((char)STK_FAILED);
return;
uint8_t flash_read(uint8_t hilo, unsigned int addr) {
return spi_transaction(0x20 + hilo * 8,
(addr 》》 8) & 0xFF,
addr & 0xFF,
0);
char flash_read_page(int length) {
for (int x = 0; x 《 length; x += 2) {
uint8_t low = flash_read(LOW, here);
SERIAL.print((char) low);
uint8_t high = flash_read(HIGH, here);
SERIAL.print((char) high);
here++;
return STK_OK;
char eeprom_read_page(int length) {
// here again we have a word address
for (int x = 0; x 《 length; x++) {
uint8_t ee = spi_transaction(0xA0, (addr 》》 8) & 0xFF, addr & 0xFF, 0xFF);
SERIAL.print((char) ee);
return STK_OK;
void read_page() {
char result = (char)STK_FAILED;
length += getch();
if (CRC_EOP != getch()) {
error++;
return;
if (memtype == ’F‘) result = flash_read_page(length);
if (memtype == ’E‘) result = eeprom_read_page(length);
void read_signature() {
error++;
return;
uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
SERIAL.print((char) middle);
uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
SERIAL.print((char) STK_OK);
void avrisp() {
uint8_t ch = getch();
switch (ch) {
case ’0‘: // signon
error = 0;
empty_reply();
break;
case ’1‘:
if (getch() == CRC_EOP) {
SERIAL.print(“AVR ISP”);
else {
error++;
break;
case ’A‘:
get_version(getch());
break;
case ’B‘:
fill(20);
set_parameters();
empty_reply();
break;
case ’E‘: // extended parameters - ignore for now
fill(5);
empty_reply();
break;
case ’P‘:
if (!pmode)
start_pmode();
empty_reply();
break;
case ’U‘: // set address (word)
here = getch();
here += 256 * getch();
empty_reply();
break;
case 0x60: //STK_PROG_FLASH
getch(); // low addr
getch(); // high addr
empty_reply();
break;
case 0x61: //STK_PROG_DATA
getch(); // data
empty_reply();
break;
case 0x64: //STK_PROG_PAGE
program_page();
break;
case 0x74: //STK_READ_PAGE ’t‘
read_page();
break;
case ’V‘: //0x56
universal();
break;
case ’Q‘: //0x51
error = 0;
end_pmode();
empty_reply();
break;
case 0x75: //STK_READ_SIGN ’u‘
read_signature();
break;
// expecting a command, not CRC_EOP
// this is how we can get back in sync
case CRC_EOP:
error++;
break;
// anything else we will return STK_UNKNOWN
default:
error++;
SERIAL.print((char)STK_UNKNOWN);
else
接下来就去引导加载程序通过这个板子烧到目标板子里面,首先在菜单里面工具-》编程器-》arduino as isp
选择选择开发板型号菜单的-》工具-》开发板:-》arduino/genuino mega或mega 2560
选择处理器菜单-》工具-》处理器-》atmega2560(Mega 2560)
烧写写引导程序菜单-》工具-》烧录引导程序
亮灯会一闪一闪,就在烧写了,电容一定要接上,菜烧不了,我是这样。
这里介绍下icsp口的定义
味噌(50个)5V
SCK(52名)MOSI(51个)
RST地线
洋洋装着这个电容是10uf的,接地
改变的地方是这样的代码
#define PIN_MOSI 11
#define PIN_MISO 12
#define PIN_SCK 13
#endif
#endif
下面附上修改的代码
// ArduinoISP
// SCK 。 。 MOSI
// 。 。 GND
#undef SERIAL
#endif
#endif
#define LED_HB 9
#define LED_ERR 8
#define LED_PMODE 7
#endif
#else
#define RESET 10
#define LED_HB 7
#define LED_ERR 6
#define LED_PMODE 5
#endif
//#ifndef PIN_MOSI
//#endif
//#ifndef PIN_MISO
//#endif
//#ifndef PIN_SCK
//#endif
//#endif
#else
#endif
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#include “SPI.h”
#else
class SPISettings {
public:
// clock is in Hz
(void) bitOrder;
(void) dataMode;
private:
uint32_t clock;
public:
void begin() {
pulseWidth = 1;
void end() {}
return b;
private:
#endif
void setup() {
pulse(LED_ERR, 2);
pulse(LED_HB, 2);
int error = 0;
int pmode = 0;
unsigned int here;
uint8_t devicecode;
uint8_t revision;
uint8_t progtype;
uint8_t parmode;
uint8_t polling;
uint8_t selftimed;
uint8_t lockbytes;
uint8_t fusebytes;
uint8_t flashpoll;
uint16_t pagesize;
uint32_t flashsize;
parameter;
parameter param;
int8_t hbdelta = 8;
void heartbeat() {
return;
last_time = now;
hbval += hbdelta;
void loop(void) {
// is pmode active?
if (pmode) {
} else {
if (error) {
} else {
heartbeat();
avrisp();
uint8_t getch() {
void fill(int n) {
buff[x] = getch();
#define PTIME 30
do {
delay(PTIME);
delay(PTIME);
} while (times--);
if (PROG_FLICKER) {
SPI.transfer(a);
SPI.transfer(b);
SPI.transfer(c);
} else {
error++;
} else {
error++;
switch (c) {
case 0x80:
breply(HWVER);
break;
case 0x81:
breply(SWMAJ);
break;
case 0x82:
breply(SWMIN);
break;
case 0x93:
break;
default:
breply(0);
+ buff[19];
reset_target(true);
SPI.begin();
reset_target(true);
pmode = 1;
void end_pmode() {
SPI.end();
pmode = 0;
void universal() {
uint8_t ch;
fill(4);
breply(ch);
addr 》》 8 & 0xFF,
addr & 0xFF,
data);
if (PROG_FLICKER) {
prog_lamp(LOW);
if (PROG_FLICKER) {
delay(PTIME);
prog_lamp(HIGH);
return here;
fill(length);
} else {
error++;
int x = 0;
commit(page);
here++;
commit(page);
return STK_OK;
error++;
return STK_FAILED;
start += EECHUNK;
return STK_OK;
fill(length);
prog_lamp(LOW);
delay(45);
prog_lamp(HIGH);
return STK_OK;
length += getch();
return;
} else {
error++;
return;
return;
(addr 》》 8) & 0xFF,
addr & 0xFF,
0);
here++;
return STK_OK;
return STK_OK;
void read_page() {
length += getch();
error++;
return;
error++;
return;
void avrisp() {
switch (ch) {
case ’0‘: // signon
error = 0;
empty_reply();
break;
case ’1‘:
else {
error++;
break;
case ’A‘:
break;
case ’B‘:
fill(20);
set_parameters();
empty_reply();
break;
fill(5);
empty_reply();
break;
case ’P‘:
if (!pmode)
start_pmode();
empty_reply();
break;
here = getch();
empty_reply();
break;
empty_reply();
break;
getch(); // data
empty_reply();
break;
program_page();
break;
read_page();
break;
case ’V‘: //0x56
universal();
break;
case ’Q‘: //0x51
error = 0;
end_pmode();
empty_reply();
break;
read_signature();
break;
case CRC_EOP:
error++;
break;
default:
error++;
else
