是的。 *如果用户需要读取ACMP引脚的ADC值,则编程流程与通常的ADC设置没有区别。 唯一的区别是引脚功能被设置为ACMP,而不是ADC。
If the user needs to read the ADC value of the ACMP pin, the programming flow is not different from the usual ADC setting. The only difference is that the pin function is set to ACMP, instead of ADC.
