MPLAB IDE v8.92在64位win7下安装多次不能使用,HI-TECH Software也装了,编译却出错,显示如下:
Release build of project `F:TestPIC TestPIC-proteusMPLAB IDE_Testchapter13[LCD]-chLCD1602_20201022S134.mcp' started.
Language tool versions: MPASMWIN.exe v5.51, mplink.exe v4.49, mplib.exe v4.49
Wed Nov 11 12:59:23 2020
Clean: Deleting intermediary and output files.
Clean: Deleted file "F:TestPIC TestPIC-ProteusMPLAB IDE_Testchapter13[LCD]-chLCD1602_20201022S134.mcs".
Clean: Done.
Skipping file. There is no tool to process the file with the given suffix.
Halting build on first failure as requested.
Release build of project `F:TestPIC TestPIC-ProteusMPLAB IDE_Testchapter13[LCD]-chLCD1602_20201022S134.mcp' failed.
BUILD FAILED
已安装过多次,编译永远是“BUILD FAILED”!!
安装主要步骤:
file:///C:UsersADMINI~1AppDataLocalTempmsohtml1\01clip_image002.jpg
