邀请回答
嗨,您可以參考Datasheet有關Power的Register,各家族應該大同小異
然後您可以設定外部中斷或者RTC觸發喚醒,以下是用外部中斷方式(PA0),新版HAL庫
/* Check and handle if the system was resumed from Standby mode */ if(__HAL_PWR_GET_FLAG(PWR_FLAG_SB) != RESET) { /* Clear Standby flag */
__HAL_PWR_CLEAR_FLAG(PWR_FLAG_SB); } /*Disable all used wakeup sources: Pin1(PA.0)*/ HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN1); /*Clear all related wakeup flags*/ __HAL_PWR_CLEAR_FLAG(PWR_FLAG_WU); /*Re-enable all used wakeup sources: Pin1(PA.0)*/ HAL_PWR_EnableWakeUpPin(PWR_WAKEUP_PIN1); /*Enter the Standby mode*/ HAL_PWR_EnterSTANDBYMode(); 以上希望對您有用
邀请回答
