天线|RF射频
元办叙
8年用户 199经验值
如何调nrf24l01无线2.4g模块stm8s与32通信
如题,我最近在调nrf24l01无线2.4g模块stm8s与32通信,无奈,可能还是自己太菜了,程序别说发送,一直卡在自检那里,根本检测不到24l01。模块是好的,换过几个。stm8s硬件spi,与原子哥的探索者407开发板通信,拿来主义的原则,网上找了好多都不行。只好来求助大家了。24l01的初始化几乎完全仿照原子哥的例程过程。主函数初始化如下二楼,工程如下,采用iar开发,stm8s103f3p6.或者哪位朋友有调好的硬件spi版本能够分享一下么?
stm8s_nrf24l01.rar (3.29 MB )
回帖(3)
李秀芳
2020-6-17 07:50:51
没,帮顶
李新梅
2020-6-17 08:10:12
void GPIO_Configuration(void)
    //无线模块的IO口初始化
    //MISO 读取数据  浮动输入,没有外部中断
    GPIO_Init(NRF24L01_CE_PORT, (GPIO_Pin_TypeDef)(NRF24L01_CE_PIN ), GPIO_MODE_OUT_PP_HIGH_FAST);//ce
    GPIO_Init(NRF24L01_CS_PORT, (GPIO_Pin_TypeDef)(NRF24L01_CS_PIN ), GPIO_MODE_OUT_PP_HIGH_FAST);//cs
    GPIO_Init(NRF24L01_SCK_PORT, NRF24L01_SCK_PIN, GPIO_MODE_OUT_PP_HIGH_FAST);//sck
    GPIO_Init(NRF24L01_MOSI_PORT, NRF24L01_MOSI_PIN, GPIO_MODE_OUT_PP_HIGH_FAST);//MOSI
    GPIO_Init(NRF24L01_MISO_PORT, NRF24L01_MISO_PIN, GPIO_MODE_OUT_PP_HIGH_FAST);//MISO
    GPIO_Init(NRF24L01_IRQ_PORT, (GPIO_Pin_TypeDef)(NRF24L01_IRQ_PIN ), GPIO_MODE_IN_PU_NO_IT); //IRQ
void init_io(void)
    delay_ms(100);          //延时 100us
    GPIO_WriteHigh(NRF24L01_CE_PORT, NRF24L01_CE_PIN);
    GPIO_WriteHigh(NRF24L01_CS_PORT, NRF24L01_CS_PIN);
    GPIO_WriteLow(NRF24L01_SCK_PORT, NRF24L01_SCK_PIN);
uchar TxBuf[TX_PLOAD_WIDTH]="abcds";
void main(void)
  SystemClock_Init();
  delay_init(16);
  UART_Init(115200);
  LED_Init();
        GPIO_Configuration();
        SPI_DeInit();//spi恢复默认设置
        SPI_ResetCRC();
       /* Initialize SPI in Slave mode  */
        SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_8, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_HIGH,
                 SPI_CLOCKPHASE_2EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT, 0x07);
        /* Enable the SPI*/
        SPI_Cmd(ENABLE);
        SPI_RW(0xff);
        CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //16MHz高速内部RC振荡器(HSI)
        init_io();
        SPI_Cmd(DISABLE);
        SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_8, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_LOW,
                 SPI_CLOCKPHASE_1EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT, 0x07);
        SPI_Cmd(ENABLE);
        GPIO_WriteLow(GPIOD, GPIO_PIN_3);//ce=0
        GPIO_WriteHigh(GPIOA, GPIO_PIN_3);//csn=1
        /* 前头检测 ------------------------------------------------------*/
        if(NRF24L01_Check()==0)
           printf("nr设备正常nr");
        else  printf("nr>>>请检查设备是否安装正确<<   while (1)
      if(nRF24L01_TxPacket(TxBuf)==TX_OK)
        printf("n 发送成功 nr");
      else printf("nr发送失败nr");
      delay_ms(500);
于佳
2020-6-17 08:17:54
楼主好,我最近也在使用stm8和***加个QQ,以后有问题跟您多多请教?1849962273,谢谢
