[AppleScript]
纯文本查看 复制代码
hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0); hHeader = LISTVIEW_GetHeader(hItem);HEADER_SetFont(hHeader, &GUI_FontHZ16);HEADER_SetBkColor(hHeader, 0x00A0A0A0);HEADER_SetDragLimit(hHeader, 0);WIDGET_SetEffect(hHeader, &WIDGET_Effect_None); hScrollbar = SCROLLBAR_CreateAttached(hItem, SCROLLBAR_CF_VERTICAL); SCROLLBAR_SetWidth(hScrollbar,20);SCROLLBAR_SetColor(hScrollbar, SCROLLBAR_CI_THUMB, GUI_BLACK);//缩略图0x00A0A0A0SCROLLBAR_SetColor(hScrollbar, SCROLLBAR_CI_SHAFT, GUI_WHITE); //轴SCROLLBAR_SetColor(hScrollbar, SCROLLBAR_CI_ARROW, GUI_GRAY); //箭头WIDGET_SetEffect(hScrollbar, &WIDGET_Effect_None);
可以自己创建滚动条添加到listview
[AppleScript] 纯文本查看 复制代码
