Microchip
王秀兰
7年用户 1322经验值
为什么MPLABX无法识别CCS编译器
您好,我尝试用CPLS编译器使用MPLABX,但是编译器没有被MPLABX识别。当打开项目属性时,X8和MPASM编译器是在编译器工具链中出现的唯一一个编译器。我试过将编译器与mpasm一起重新安装到MPLABX v.3.35程序文件目录中,但是仍然没有显示。我试着自己打开编译器,它成功地构建了我的项目,但是不能用PickIt 3来编写芯片,所以我需要让它与MPLABX一起工作。
以上来自于百度翻译
      以下为原文
    Hi, I am trying to use MPLABX with a CCS compiler, but the compiler is not being recognized by MPLABX. When I open project properties the X8 and mpasm compilers are the only ones that show up under the compiler toolchain. I have tried reinstalling my compiler into the MPLABX v.3.35 program file directory, alongside mpasm, but it still doesn't show up. I have tried opening the compiler on its own, and it builds my project successfully, but does not work with the PickIt 3 I am using to program my chip so I need to have it working with MPLABX.
Is there anything I need to do to have MPLABX see the compiler as an option?
回帖(3)
李天竹
2019-7-23 08:28:18
你可能应该问问CCS供应商。
以上来自于百度翻译
      以下为原文
    You probably should ask the CCS vendors.
陈晨
2019-7-23 08:43:15
你有安装CCS插件吗?
以上来自于百度翻译
      以下为原文
    Do you have the CCS Plugin Installed?
王耀昱
2019-7-23 08:54:06
嗨,它非常简单-尝试用工具重新安装:setup_mplabx_plugin.exe或在MPLLABX中转到菜单项:tools-.-building tools->并搜索CCS编译器“Add”或“Add custom compiler”——其中之一可以工作。中间带有一条消息,例如“new installed compiler”。您还可以通过注册给定的文件夹来手动搜索。然后您可以将编译器标记为默认编译器。
以上来自于百度翻译
      以下为原文
Hi,
its very easy - try reinstall with the tool: setup_mplabx_plugin.exe
Or go in the MPLABX to the menu item: tools - options - building tools -> and search for the CCS compiler "Add", or "Add custom compiler" -- one of this will work.
Or if was installed with the mplabx_plugin you'll find this immediately with a message eg "new installed compiler".
You can also search for manually by register the given folders.
Then you can mark your compiler as default compiler.
Gerald
