是德科技
张玉
8年用户 265经验值
请问M9381A PXI矢量信号发生器支持哪些ARB文件格式?
您好,M9381A PXI矢量信号发生器支持哪些ARB文件格式?
谢谢!
以上来自于谷歌翻译
     以下为原文
  Hi there,
What ARB file formats are supported for the M9381A PXI Vector Signal Generator?
Thanks!
李欢
2019-7-22 10:28:15
嗨 - 软前面板(SFP)支持以下文件格式:•Signal Studio(.wfm)•二进制(.bin)(单或双,自动检测)•文本文件,逗号分隔(.CSV)或制表符分隔(
.txt)•Matlab文件(.mat)使用API​​,M9381A驱动程序提供了几个接口,用于将波形加载到VSG中。
使用Agilent Signal Studio应用程序创建的波形可以直接加载到M9381A中,允许用户在M9381A和其他安捷伦信号发生器(如N5182B MXG信号发生器)之间使用完全相同的调制数据文件。
对于Signal Studio文件,API只需要波形的参考名称和文件的完整路径。
具有单精度或双精度浮点和16位整数格式的交错I和Q数据的二进制数据文件也可以直接加载到M9381A中。
IVI驱动程序中还有一些方法可以从数据数组加载这些相同的数据格式,允许用户从其他文件格式导入数据或直接在应用程序中生成波形数据。
有关M9381A的更多信息,请访问:http://www.agilent.com/find/M9381A我希望这有帮助 -
以上来自于谷歌翻译
     以下为原文
  Hi -
The soft front panel (SFP) supports the following file formats:
•     Signal Studio (.wfm)
•     Binary (.bin) (Single or Double, automatic detection)
•     Text Files, Comma separated (.CSV) or Tab separated (.txt)
•     Matlab Files (.mat)
Using the API, the M9381A driver provides several interfaces for loading waveforms into the VSG.  Waveforms that are created with the Agilent Signal Studio applications can be directly loaded into the M9381A, allowing users to use the exact same modulation data files between the M9381A and other Agilent Signal Generators, such as the N5182B MXG signal generator.  For Signal Studio files, the API simply needs a reference name for the waveform and full path to the file.
Binary data files with interleaved I and Q data in single or double precision floating point and 16 bit integer formats can also be loaded directly into the M9381A.  There are also methods in the IVI driver to load these same data formats from arrays of data, allowing the user to import data from other file formats or to generate the waveform data directly in the application program.
More information on the M9381A can be found here: http://www.agilent.com/find/M9381A
I hope this helped -
