赛灵思
张慧
7年用户 213经验值
请问我是否必须选择具有相同线路速率(3.125)的SFP模块?
嗨,大家好,
我正在研究两个FPGA(Spartan 6 LX150T)板之间的高速数据链路。
到目前为止,我使用迷你DisplayPort作为链接,但我想切换到SFP模块。
现在我的问题是:GTP收发器的线路速率为3.125 Gb / s,并且实现了自定义协议,我是否必须选择具有相同线路速率(3.125)的SFP模块?
因为它是安静的diffucult找到一个,它支持这个线速率。
或者我可能采用线速率为4.25 Gb / s的SFP模块,但收发器的线速率仍为3.125 Gb / s?
总结我的问题是:支持“线速率高达4.25 Gb / s”的SFP模块是否可以与GTP收发器配合使用,其线速率仅为3.125 Gb / s?
问候,flor1an
以上来自于谷歌翻译
以下为原文
Hi everyone,
i am working on a high-speed data link between two FPGA ( Spartan 6 LX150T) boards. Until now i am using mini DisplayPort as for the link but i want to switch to a SFP module. Now my question is: The GTP transceiver has a line rate of 3.125 Gb/s and there is a custom protocol implemented, do i have to choose a SFP module with the same line rate (3.125)? Because it is quiet diffucult to find one, which supports this line rate. Or is it possible that i take a SFP module with a line rate of 4.25 Gb/s but the transceiver still has a line rate of 3.125 Gb/s?
To sum up my question is: Does a SFP module, which supports "line rates up to 4.25 Gb/s", work with a GTP transceiver, which line rate is only 3.125 Gb/s?
Regards, flor1an
