ST意法半导体
卞轮辉
7年用户 1029经验值
如何通过ST NFC Tap iPhone应用程序来识别M24LR64E-R
我使用的是M24LR64E-R,我似乎无法通过ST NFC Tap iPhone应用程序来识别它。我可以使用带有M24LRE-R的M24LR发现板。
我很确定我在M24LR64E-R上有一个有效的NDEF记录。但是,当我使用Android ST25应用程序读取这两个标签时,它会为发现板列出“NFC类型V - ISO / IEC 15693”,但仅列出我的电路板的“ISO / IEC 15693”。我甚至尝试从发现板上保存内存并将其倾倒在我的上面,没有运气。
是否可以用iPhone读取M24LR64E-R?
#ios #nfc#m24lr
以上来自于谷歌翻译
以下为原文
I'm using a M24LR64E-R and I can't seem to get the ST NFC Tap iPhone app to recognize it. I can get it to work with the M24LR-discovery board which has the M24LRE-R on it.
I'm pretty sure I have a valid NDEF record on the M24LR64E-R. However, when I read both tags with the Android ST25 app, it lists 'NFC type V - ISO/IEC 15693' for the discovery board, but only lists 'ISO/IEC 15693' for my board. I have even tried saving the memory from the discovery board and dumping it on mine, with no luck.
Is it possible to read a M24LR64E-R with an iPhone?
#ios #nfc #m24lr
鲍淑君
2019-7-18 16:19:52
亲爱的布赖恩,
不幸的是,iPhone不支持M24LR64E-R。它仅在Android平台上受支持。
截至今天,iOS11不支持具有大于8Kbits的存储器的NFC-V / ISO15693标签。
最好的祝福,
以上来自于谷歌翻译
以下为原文
Dear Brian,
Unfortunately, M24LR64E-R is not supported by iPhones. It is only supported on Android platforms.
As of today, iOS11 is not supporting NFC-V / ISO15693 tags with memories larger than 8Kbits.
Best regards,
