我正在尝试用I2C主控器来复用GPIO PIN功能,而我似乎不能把它作为输出来工作。
我可以让PIN输入并读取它;如果我从引脚上断开I2C模块的原理图,PIN工作得很好,所以我知道我的硬件是好的。
以下是我的代码:
int()
UIT88T温度=A4YBYP;
温度=温度和0xFe;
A4YBYP =温度;
A4X设置驱动器(A4A);
A4-写(0);
A4-写(1);
CyDelay(500);
A4-写(0);
CyDelay(500);
有什么想法吗?
迈克
以上来自于百度翻译
以下为原文
I'm trying to mul
tiplex GPIO pin functionality with an I2C master, and I can't seem to get it to work as an output.
I can make the pin an input and read it; if I disconnect the I2C module on the schematic from the pin, the pin works just fine, so I know my hardware is good.
Here's my code:
int main()
uint8_t temp = A4_BYP;
temp = temp & 0xFE;
A4_BYP = temp;
A4_SetDriveMode(A4_DM_STRONG);
A4_Write(0);
for(;;)
A4_Write(1);
CyDelay(500);
A4_Write(0);
CyDelay(500);
Any ideas?
Mike
