你好:
我使用带有VIPer38LE芯片的eDesignSuite设计了一个
电源......电源输入为11.1瓦,96-144 Vac,60hz,运行频率为60KHZ。有没有一种方法可以确定推荐的滤波器
元件是X2电容和共模输入电抗器?还有NTC吗?
谢谢,汤姆
#common-mode-choke #ntc#x2#emi-filter
以上来自于谷歌翻译
以下为原文
Hi:
I have designed a smps using eDesignSuite with a VIPer38LE chip... the Power In is 11.1 watts, 96-144 Vac, 60hz and will run at 60KHZ. Is there a method for determining the recommended filter components being X2 caps and the Common mode input choke? Also the NTC?
Thanks, Tom
#common-mode-choke #ntc #x2 #emi-filter
