Y,
通常,如果您需要将接收时钟用于其他收发器,您可以通过使用适当的低通相位检测器滤波器时间常数通过外部PLL来清理它(Xilinx FPGA上的PLL不一定具有
适当的过滤要求)。
这个时钟的阶段并不重要。
如果分配接收时钟而不滤除抖动,则传输的抖动可能过大,并且使用该时钟源的所有链路都会产生数据错误 - 请勿这样做!
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
y,
Typically, if you need to use the receive clock for other transceivers, you would clean it up by passing it through an external PLL with the proper low pass phase detector filter time constants (the PLL on the Xilinx FPGA is not necessarily going to have the proper filter requirements).
The phase of this clock is not important.
If you distribute the receive clock without filtering out the jitter, the transmitted jitter may be excessive, and data errors will result on all those links using that clock source -- don't do it that way!
Austin Lesea
Principal Engineer
Xilinx San Jose
Y,
适当的过滤要求)。
这个时钟的阶段并不重要。
以上来自于谷歌翻译
以下为原文
y,
Austin Lesea
Principal Engineer
Xilinx San Jose
